Outer Tie Rod Boot is ripped
Old Jun 20, 2021 | 03:09 PM
vrt_luv's Avatar
Default Outer Tie Rod Boot is ripped
Hi Guys,
I recently changed my wheels and noticed that the boot on the outer tie rod has ripped. I drove it today and didn't notice anything significant other than a flighty steering wheel response. Could the boot be causing this issue?
If I were to replace this what other part should be changed in the process?
Can I continue to drive the car like this or should this be changed immediately?
Passenger Front Tie Rod
Old Jun 20, 2021 | 04:31 PM
darcyw's Avatar
remove the cotter pin, remove the tie rod from the knuckle. Feel for play and looseness. Its my experience that it should be fairly stiff with no play. If the boot just split and no water infiltrated the tie rod end, you may just need to remove the rubber seal, clean, and regrease. But, if its rusted and loose, then replace the outer tie rod end. They are fairly easy to replace.
I mean, I wouldn't want to be driving on it for long in its current condition.
darcy
Old Jun 20, 2021 | 04:55 PM
boyguan's Avatar
Just replace the tie rod end. The oem boot is like 15 and a new tie rod end was 38.
Old Jun 21, 2021 | 11:58 AM
Car Analogy's Avatar
...and to state the obvious, get alignment if you replace the tie rod or change threaded adjustment at all.
If joint is still good, you can just replace boot, add some fresh grease as good measure, reinstall toe rod and no alignment needed.
Old Jun 22, 2021 | 03:06 PM
B serious's Avatar
If you do buy a tie rod, buy one from a Honda dealer
the steering response issue is probably in your head since you just noticed it at the same time as you noticed the torn boot
Old Jun 22, 2021 | 03:56 PM
rrounds's Avatar
Why Honda? Lots of good tie rod ends out there. I use Moog tie rods on all my cars.
Rod
Old Jun 22, 2021 | 07:52 PM
B serious's Avatar
Rod
It probably depends on what kind of car you have.
Speaking about Hondas...
Most aftermarket tie rods won't last more than 10K miles if you're lucky. In comparison, there's quite a few 200K+ mile Hondas with factory installed tie rods. And they never needed service or maintenance.
There isn't virtually any aftermarket part that's better made than the factory one for anywhere near the same price point anywhere on this car, if you think about it.
The testing that OEM's do nowadays is impressive. In my experience, its borderline unsafe to go to "OE equivalent" aftermarket replacement chassis parts. That's not being dramatic. Its all quite badly made...
Old Jun 23, 2021 | 10:15 AM
boyguan's Avatar
Rod
if you look at the cost, its not much more for a honda
Old Jun 23, 2021 | 05:34 PM
vrt_luv's Avatar
Thanks guys, I think I'll go ahead and just replace the tie rod ends
Does anyone know if there's a difference between the part number for left and right?
The part number I found is 53540-S47-951, there seems to be no indication that these are directional
Are both left and right outer tie rod the same?
Old Jun 24, 2021 | 06:08 AM
boyguan's Avatar
yes they are the same. One trick is to measure the stock tie rod, i am pretty sure they are the same length. Back off the jam nut just a bit. Count the number of turns to remove the original tie rod. Screw the new one back on, they should be exactly the same amount of turns. This will get you really close to the previous alignment so you can drive it there. Just make sure the tie rod itself doesnt spin (it shouldnt but clamp a vice grip to be sure)
imstimpy
Jul 16, 2017 05:40 AM
captb
Oct 7, 2016 07:57 PM
tozerman
May 26, 2016 02:53 AM
IntegraR0064
Jun 13, 2011 07:43 PM
mbroder@umd.edu
Jun 29, 2009 12:10 PM
