Painting Calipers
Old Aug 5, 2002 | 02:17 PM
Eze8199's Avatar
Default Painting Calipers
I want to try and paint my calipers red soon. I just want to know, what is a good paint to use? About how long will it take? And any other usefull info. Thanks
Old Aug 5, 2002 | 02:49 PM
wanabe's Avatar
[QUOTE]Originally posted by Eze8199
[B]I want to try and paint my calipers red soon.
Old Aug 5, 2002 | 02:52 PM
Eze8199's Avatar
Where can I order that kit? Thanks
Old Aug 5, 2002 | 02:53 PM
wanabe's Avatar
just found the site... they changed the kit. this is different than the one they had when i painted mine. probably just as good-
http://seriousauto.com/hard-parts/caliper-...aint-index4.htm
Old Aug 5, 2002 | 03:04 PM
Eze8199's Avatar
Thanks for your help.
Old Aug 5, 2002 | 03:06 PM
wanabe's Avatar
you are welcome...
take your time with it,
and good luck!!
Old Aug 5, 2002 | 03:16 PM
Xv7vX's Avatar
I just painted my calipers a couple days ago. I went with the G2 kit. You can purchase the kit from optionsauto.com. It cost about $50 an it took about 3 hrs. I can post pictures or walk you through the process if you PM me.
thanks
Xv7vX
Old Aug 5, 2002 | 03:59 PM
Indecision's Avatar
You don't need those expensive kit, I think they're a big rip off. I've painted 2 of my car with engine header paint (heat resistance up to 260C) and it lasts about 4-5 years before requiring another repaint. The brand is "Plasti-Kote" bottle label "Engine Enamel" cost about $7-8 a spray bottle.
For best result apply 2-3 thin layers. Here is how I did mine:
1. wrap everything except your caliper with newspaper, wrap small gaps between the caliper as well.
2. spray one layer, let it settle (should take about 15-20minutes)
3. spray another layer, repeat 2 for up to 3 layers
4. do the same on each wheel
5. let the paint settle for 24hrs before driving out
*make sure to only spray the caliper and nothing else, use masking tape to cover the small gap.
result:
Old Aug 5, 2002 | 06:27 PM
Eze8199's Avatar
What color do you guys think I should make my calipers, red or black? I'm leaning towards black because I'm worried about the red not matching the rest of the car correctly, plus black will hide dirt better.
Old Aug 5, 2002 | 07:13 PM
gomarlins3's Avatar
I went with the G2 kit as well. Couldn't have been easier.
