Painting Calipers
Old Aug 5, 2002 | 07:37 PM
ASMspec's Avatar
Get rid of those and get these. No painting required.
I used normal high temp paint for my rears. Its lasted over a year and its silver.
Old Aug 5, 2002 | 08:16 PM
traynspotting's Avatar
is it that easy to take the tires off and on? are you guys doing this at body shops or in your own garages? everytime i visit a service center, they use this highpressure machine to take it off.
i want to paint my calipers red too! i your red gomarlin3!
Old Aug 5, 2002 | 08:50 PM
suzukablus2k's Avatar
Taking wheels off and putting them back on is the easiest part. Painting the calipers requires a lot of prepping and patience. However, the result is well worth the time. You can do all this right in your own garage. Took me about 4 hours total because I like mine to come out perfect.
Old Aug 5, 2002 | 09:35 PM
[QUOTE]Originally posted by suzukablus2k
[B]
Old Aug 5, 2002 | 09:55 PM
Sorry Jane, I'm going to be out of town that weekend. You guys have fun.
Nathan
Old Aug 6, 2002 | 05:00 AM
Yellow Streak's Avatar
When I painted my calipers, I also addressed the rusty rotors issue. I treated the small inner ring of rust closest to the hub and the outer cooling slots with rust converter. I waited twenty four hours and then painted them with brush on BBQ black.....no more rust. If you get a little paint on the rotor surface, it will come right off under braking.
-YS
Old Aug 6, 2002 | 06:00 AM
jvils's Avatar
I painted mine red with 900 degree high-temp paint, $3.99 +tax at pep boys. Took me about 4 hrs, most of that was cleaning and masking off everything with newspaper. Just go slow and be patient. I did two thin coats, then one heavy coat, and one more thin one. Also, many high temp paints need to be cured or they rub off. Read the bottle, mine said 650 degrees for 30-60 minutes, within 8 hrs of application. So I just went out and drove hard for an hour; think of it as a bonus. Probably didn't hit 650, but it turned out great.
This pic is OK, but the red is shadowed. Looks brighter than this.
Old Aug 7, 2002 | 12:32 AM
what was it called? maybe the inventory at pep boys is the same for florida & california
how long ago did you do this? and has the paint dulled since?
thanks!
Old Aug 7, 2002 | 04:27 AM
Surf2k's Avatar
[QUOTE]Originally posted by wanabe
[B]
i used a kit from the miata site...
it came with everything i needed except for the jack and jack stands-
the only paint to use is an epoxy based paint, to withstand the high temps.
Old Aug 7, 2002 | 04:58 AM
jvils's Avatar
Plasit-kote Hot Paint - Ultra High Temperature (900F). I used HP-13 Red. This is flat red; a little gloss would be nice, but I like the way it turned out.
It's been two or three weeks, still looks great. I think KeithD used the same paint (black) and did a couple auto-x's with no fading or cracking. The 500-600 degree paint will chip.
