Passanger side window won't roll up...
Old May 22, 2003 | 10:49 AM
Kenny_Stang's Avatar
Default Passanger side window won't roll up...
Went to get my car cleaned today, and when putting the top down the window rolled down. When I returned to work, I put the top up and then the windows and noticed the passenger side window didn't roll up. Tried the button on the passenger side door to see if I could roll up the window with that one, but it still stayed down. I don't even hear the motor engaging or anything happening when I push the button. Is this unusual? The car is a MY01 w/ 16K miles and still under warranty. Should I just take it in?
Old May 22, 2003 | 10:52 AM
dangarza's Avatar
Check fuses. If all OK. Yes, take it to dealer. It should be covered under warranty.
Daniel
Old May 22, 2003 | 10:54 AM
stockae92's Avatar
check the master switch for passenger side window on the driver side
Old May 22, 2003 | 10:59 AM
What do I check for? I did try both switches, the one on the drivers side, and the one on the passenger side door, neither worked. Where's the fuse box on the S2k, I don't have my owners manual with me.
Old May 22, 2003 | 11:01 AM
ViruX23's Avatar
ummm, turn the safty switch off...
the on off button next to the window buttons on the driver side...
Old May 22, 2003 | 11:03 AM
I thought that only controlled the passenger from rolling the passenger window up down, or does it affect both switches?
Old May 22, 2003 | 11:05 AM
Busch's Avatar
it prevents the both switches from rolling up the passenger side...
but it can roll down.
Old May 22, 2003 | 11:09 AM
Well that may be what happened since I was cleaning the car I might have turned it off.
Old May 22, 2003 | 11:10 AM
ViruX23's Avatar
wow. honestly, im at a loss for words here
Old May 22, 2003 | 11:19 AM
rworne's Avatar
Not me. I think the design of the "master switch" as well as the "lock only" passenger side door are about the most asinine things I have seen on an otherwise well-designed car.
The master switch should only disable the passenger side power controls.
There should be a way to unlock the passenger door from the driver's seat.
The odd mechanical safety to prevent the doors from locking when they are open is wierd too.
I guess I am just too used to the way Toyota does it (the right way).
