passenger window and top won't go down
Old Jul 17, 2006 | 02:03 PM
mrmumbels's Avatar
Default passenger window and top won't go down
I have searched on this topic and it seems everyone that has a broken passenger window has the child safety lock on. Well, this is not my case. I have tried everything but my passenger window will not go down and neither will the convertible top.
Window lock switch in the on position
There's no click when i hit the window or top buttons
plugs are all conected
both fuses are fine
no power coming out the motor plug when i hit the switch.
switch for conv top is on good n tight
all door plugs are on good and tight
Can anyone think of anything else i can test and how to test it??
Pleasee!!!
Old Jul 17, 2006 | 03:52 PM
xviper's Avatar
Check the connector under the power top button (under center console). It may have come loose. And for sure the connector is on tight in the passenger door for the window switch and motor?
Old Jul 17, 2006 | 04:41 PM
mrmumbels's Avatar
nope, just checked it and it's connected. passenger door connectors are on good and tight.
Old Jul 17, 2006 | 05:01 PM
ness1216's Avatar
If you hear a click then I would assume the actual switch isnt working. Maybe just a new switch? Or maybe one of the relays went bad.
Old Jul 18, 2006 | 03:21 AM
mrmumbels's Avatar
i don't hear a click of a relay. where is this relay? i know there's a click in the driver switch when i put the driver window down.
Old Jul 18, 2006 | 06:30 AM
xviper's Avatar
When you hit the button to lower the top, are you saying that nothing happens? Or just the driver's side window goes down and nothing else works?
Old Jul 18, 2006 | 06:35 AM
mrmumbels's Avatar
when i hit the button for the top to go down nothing happens.
BTW it started working again this morning after not working for 4 days. Like i said, it's intermittent. I did listen for the relay today. Is there also a relay in the passenger door switch? That could be a possibility.
Old Jul 18, 2006 | 08:30 AM
xviper's Avatar
[QUOTE=mrmumbels,Jul 18 2006, 08:35 AM] when i hit the button for the top to go down nothing happens.
Old Jul 18, 2006 | 02:23 PM
mrmumbels's Avatar
well like i said earlier the whole thing started working again but i'd really liek to get to the bottom of this.
xviper, the only thing that worked was the driver window from any switches. i'm guessing now that it works that i won't be able to troubleshoot it. it just sucks cause i never knwo when it's going to break. with my luck i'll be in a place where i really need the window up.
Old Jul 18, 2006 | 04:39 PM
Chazmo's Avatar
Parking brake on?
