Permanent fix to windscreen vibration/oscillation
Old May 30, 2001 | 01:34 PM
Rick Hesel's Avatar
Former Sponsor
I've been experimenting with a permanent fix to the vibration/oscillation issue(our rubber foam strip solution is temporary in that the foam has to be replaced periodically).
In a nutshell, my fix involves screwing two very small rubber bumpers into the plastic roll hoops, one each just at the top of each ear on the mechanism, on the interior side, placed so they put slight pressure toward the rear of the car against the spring tension of the mechanism.
Without the bumpers, the wind pressure pushes the screen toward the front of the car, against the tension of the spring mechanism in the hinges. Variations in the wind pressure against the spring tension causes the oscillation or vibration. The bumpers keep the screen from oscillating forward as the wind pressure varies, and the faster you go, the better they work. At high speed there is no vibration of any kind and at lower speed very little, most of it caused by road bumps.
Two small holes have to be drilled in the hoops, so this may not appeal to those of you who hate to do this kind of thing to the car. But it's a set and forget solution, good for the life of the car.
I'll be posting pictures and instructions this weekend.
Old May 30, 2001 | 01:41 PM
Mossad's Avatar
I anxiously await the pics. I love the look of my Rick's deflector, but after only a month, it's already vibrated itself loose from the ears, even with the foam inserts.
Old May 30, 2001 | 02:13 PM
mns2k's Avatar
Rick:
For whatever its worth went to Home Depot and purchased some clear plastic furniture bumpers. They are self adheasive. They wedge the aeroscreen in place. At 85+ there is no vibration. No need to drill as you can trim them to fit neatly and being clear they are not noticable. I think they cost about $1.59 for a pack of 6.
Dan
Old May 30, 2001 | 02:16 PM
Knowledge's Avatar
Dan, post some pictures, please!
Old May 30, 2001 | 02:19 PM
mns2k's Avatar
[QUOTE]Originally posted by Knowledge
[B]Dan, post some pictures, please!
Old May 30, 2001 | 04:02 PM
Rick Hesel's Avatar
Former Sponsor
Mossad,
If the ears are loose, you need to glue them with high qualilty super glue, like Goldberg's SuperJet. Once you do this they will not come loose again.
Old May 30, 2001 | 04:03 PM
Rick Hesel's Avatar
Former Sponsor
mns2k,
Sounds like a good solution. I just wanted to find a solution that avoided wedging anything between the ears and the hoops.
Old May 30, 2001 | 05:12 PM
Gators1's Avatar
Rick, I purchased your 7/8 windscreen. I have completed the assembly, and I am waiting for the silicone to dry. I am a little confused about the anti vibration solution. Should I use the weather stripping you provided, or should we follow the clear plastic furniture bumper you refer to in the installation manual. Or do we wait for your permanent fix? Help GaToR
Old May 30, 2001 | 06:02 PM
Rick Hesel's Avatar
Former Sponsor
I would wait a few days until I can post the pictures for the permanent solution. In the meantime, you might want to use the rubber foam solution.
tcjensen
Mar 24, 2014 02:28 AM
boyguan
Mar 30, 2013 04:44 AM
Dracoro
Apr 21, 2011 12:21 AM
Rick Hesel
Sep 20, 2001 03:27 AM
Rick Hesel
Jul 17, 2001 01:19 AM
