Pic of my Neuspeed STB installed
Old Nov 20, 2000 | 10:10 AM
1Y2KS2K's Avatar
Originally posted by nvmys2k:
Was it pretty easy to install the STB? Did you have to use the torque-wrench? Thanx.
If you try it out first by lowering the bar over the existing strut nuts (2 at each end), it will appear as though the STB is about 3/8" too long; you won't be able to get one end to drop over the threads (even though the STB has elongated slots). To install it, you have to take all four screws out first, which will release the strut tower (making it "relax"), then you should be able to drop the STB over the two threads on each tower. (You just might have to "spring" the bar down on one end. It's a pretty tight fit.) You can get the right kind of torque by tightening the nuts down with a ratchet or wrench, then when it's tight, an extra "kick" should do it. (No need to use superhuman strength!)
h22boy
Jun 27, 2007 10:21 PM
wantgoback
Feb 26, 2007 07:39 PM
tenblade2001
Oct 6, 2003 04:06 AM
BB AP1
Mar 25, 2001 04:35 PM
Rick Hesel
Nov 21, 2000 06:48 PM
