Place for CD changer
Old Dec 30, 2000 | 01:03 PM
Ronald's Avatar
Hi,
I'm thinking about the best place for
installing the CD changer. Have seen a lot
of ideas for installing better speakers. But
I have never seen a good place the changer.
I don't like the standard place in the boot.
Is there enough room next to the spare tyre?
Ronald
Old Dec 30, 2000 | 01:44 PM
pancho's Avatar
Ronald
I just took out the spare tyre.
Groeten uit vlaanderen
Old Dec 30, 2000 | 01:49 PM
Ronald's Avatar
I've been thinking about that option too. At
least it saves some weight too! Do you have
an emergency spray can for 'repairing' a
puncture instead?
Ronald
Old Dec 30, 2000 | 01:52 PM
pancho's Avatar
Yes, i haven't used it yet, but I used it in the past for my motorcycle and it works.
Old Dec 30, 2000 | 07:26 PM
elviscos's Avatar
i can't think of better place then in the dash Alla- Nakamichi mb-75
Old Dec 30, 2000 | 07:56 PM
Zoinks's Avatar
What's wrong with the factory mount? Looks OK with the cover. The metal cage is rather nice too. I don't know if you can buy these pieces seperately from the factory changer.
I installed a Kenwood changer since I took that pic. Put it in the same place.
Old Dec 31, 2000 | 01:57 AM
Ronald's Avatar
Well, I think it's quite vulnerable when
the changer is mounted like this. I presume
you don't have any bad experience with
this setup?
Ronald
Old Dec 31, 2000 | 02:44 AM
Muz's Avatar
Muz
Former Sponsor
IMO it's not vunerable at all. It's a sturdy unit that you should have no problems with unless you are really abusing it.
Old Dec 31, 2000 | 06:09 AM
jim's Avatar
jim
My garage suggested putting in a changer in the wall to the left of the spare tire. As this required drilling out a large area, I decided not to tamper with what might be structural material. Probably isn't, but I still don't like the idea of knocking out a large bit of metal.
Front load CD player is not part of the Spanish specs, so can't even be ordered with the car! Drag! Still, I never even put the radio on. Thought it sucked first time I tried it, and it doesn't match up to the music of the motor! I listen to music when I get home.
No room in the trunk for a openly mounted CD changer if one wishes to squeeze in a suitcase & a trombone case, as I must.
By the way, I made the dealer come to my house with an S2000 to make sure it could come up the drive (large dip which the front end clears by only about 1 cm!), and that the 'bone case would fit in the trunk, before I bought the car. :>
Jim
Old Dec 31, 2000 | 06:45 AM
lvs2k's Avatar
You got the dealer to come to your house? That's as unheard of as a doctor coming to your house.
