please educate me on sway bars
Old May 18, 2007 | 06:13 PM
duality's Avatar
Default please educate me on sway bars
I want to tighten up the steering on my car, but have no idea how large of a sway bar to get, what brands to be looking at, or any other info. Please educate me!
Old May 18, 2007 | 06:19 PM
iam7head's Avatar
what do you mean by tightening up the steering?
the swap bar will only change the body motion during a cornering
Old May 18, 2007 | 06:51 PM
smurf2k's Avatar
the more accurate name is anti-sway bar
they reduce roll
Old May 18, 2007 | 06:59 PM
duality's Avatar
they reduce roll
Understood that, but they are more commonly referred to as sway bars. And by tighten up the steering I meant to better the handling, I know the steering ratio is unchanged. At any rate, I guess I'm just looking for appropriate sizes and manufacurers.
Old May 18, 2007 | 07:27 PM
Guld's Avatar
Thicker bars reduce traction and thinner bars add traction. This follows the concept that having a thicker bar will make it harder for the suspension to follow the irregularities of the road.
In other words, if you go for a thicker bar on the rear you will alter the balance towards getting more oversteer (loose rear end). If you go for thinner on the front you will also alter the balance towards getting more oversteer (loose rear end).
On the other hand, if you add bar to the front of the car, you will get more understeer (the car will push). Similarly, if you put a thinner bar on the rear, the car will understeer as well (will push).
In conclusion, its a compromise between front and rear traction.
EDIT: I'm not sure if this is the answer you were looking for. The bottom line is that you select the combination that suits your driving style/abilities. IMO, there's no such thing as a universal setup.
Old May 18, 2007 | 09:08 PM
ShocK's Avatar
Is there any kind of rating system used for sway bars? Kinda like they rate springs kg/mm.
Old May 18, 2007 | 09:27 PM
kalibo's Avatar
Usually they go by thickness in mm.
Old May 18, 2007 | 10:15 PM
ShocK's Avatar
that doesnt seem very accurate, I mean theres 100 different metals that all act differently then theres thickness of the metal, too many factors for them to just say 25mm sway bar, hmmmm oh well.
Old May 18, 2007 | 10:30 PM
smurf2k's Avatar
right - alloy, and the design of the bars
the thickness is just for relative comparison between same design bars from same manufacturer. besides, even if the stiffness was given in si units, it would be irrelevant to many people
Old May 18, 2007 | 11:15 PM
TheDonEffect's Avatar
I found that informative, thanks, more input please.
donatello
Aug 23, 2014 11:23 AM
Nickfromny
Mar 30, 2009 10:45 AM
Amer
Sep 6, 2006 09:35 AM
Stw000
Feb 16, 2005 01:29 PM
probert
Apr 23, 2004 07:53 AM
