pls help with gearbox/clutch
Old Apr 8, 2011 | 08:13 AM
dyhppy's Avatar
Default pls help with gearbox/clutch
i sometimes have trouble getting my shifter out of gear even when the clutch is fully depressed. have to use a good deal of force to get it back into neutral. not sure why and could use help.
i installed a axialflow shortshifter many yrs ago. also have a aftermarket stiffer pressure plate and lightweight flywheel. clutch pedal pressure is high/normal feeling. when i come to stop with the clutch fully depressed, the car doesnt stall so i figure the trans is not connected.
doesnt make sense to me. pls help. im betting it's related to the throwout bearing?
thnx
Old Apr 10, 2011 | 12:59 PM
dyhppy's Avatar
Bump. Can anyone pls help?
Old Apr 11, 2011 | 10:05 AM
whippets2k's Avatar
Have you checked/inspected clutch fluid, master cylinder, and slave cylinder already?
Old Apr 12, 2011 | 08:04 AM
dyhppy's Avatar
checked fluid, but not the other components. just trying to understand what could be wrong in theory.
Old Apr 12, 2011 | 08:15 PM
EssToOfouzEn's Avatar
I have the same problem but my issue started when i installed my puck clutch with chromolly flywheel and PP. Im still under investigation on what the issue really is but i was told its the slave cylinder
dyhppy
Sep 14, 2013 10:42 PM
drunkpunks3
Mar 29, 2012 07:58 PM
josh7owens
Feb 18, 2010 05:38 PM
nightime
Socal Swap Meet
13
Feb 3, 2010 06:58 PM
osu s2k
Apr 16, 2004 07:51 PM
