Pre 2006 DTRL
Old Apr 5, 2008 | 03:34 PM
rnye's Avatar
Default Pre 2006 DTRL
I would like to know if its possible to run day time running lights on my S2000.
I want to be a ricer and run yellow bulbs all the time - preferably at 100% brightness because of how dim yellow bulbs look vs half power of DTRL on the 06+s. Is there a way retrofit/run DTRL in my 05?
I've seen people use yellow bulbs in the high beams, but I want to be able to run them without the HIDs being on. Any ideas?
Thanks.
Old Apr 5, 2008 | 03:51 PM
ace123's Avatar
you could wire an on-off switch to an 'ignition on' wire such as the blue acc wire behind the radio. the wire gives positive voltage (small, not enough to power the lights) when the ignition is on. if you buy a pass/no pass switch that is positive when it senses a voltage (radio shack etc) and replace the on/off switch that comes with your lights with it, you've got DRLs.
Old Apr 5, 2008 | 05:18 PM
frofro24's Avatar
I know the USDM S2000 has a spot for a fuse. I bet you could get the wiring harness from a non USDM S2000 and wire it up.
Old Apr 5, 2008 | 06:33 PM
FISH22's Avatar
Saw a write-up on this site a while back with a DIY for DRL's.
Old Apr 5, 2008 | 06:42 PM
rnye's Avatar
Thanks - I found this one:
http://alavigne.net/Motorsports/FeatureRep...0/DRL/index.jsp
Way more involved than I thought..
Spec_Ops2087
Mar 23, 2009 12:25 PM
bayarea408
Sep 1, 2008 07:43 AM
S2KJOY
Feb 1, 2008 04:53 AM
Davizzle
Dec 23, 2007 03:26 PM
kidwhiz
Sep 4, 2003 08:56 AM
