primary and seconday O2 sensors...
Old May 18, 2005 | 06:24 PM
Ooalloems2koO's Avatar
Default primary and seconday O2 sensors...
if anyone has pictures of primary and secondary pictures please post.....
thank you!
i need to know which one goes where...
Old May 18, 2005 | 09:24 PM
xviper's Avatar
I've seen them both and in my eye, you can't really tell them apart. Visually, they look the same. Maybe the numbers are different?
You can see a new one that goes into the cat in the O2 simulator thread:
https://www.s2ki.com/forums/index.php?showt...dpost&p=4560255
I have a photo of the one that goes into the header but the photo albums are buggered so I can't post it.
Old May 18, 2005 | 10:04 PM
moparacker's Avatar
Each sensor will only plug into one spot on the car. The wiring for both sensors are almost the same at the connector, but one wire is slightly different for the secondary sensor. Check each O2 connector (the part on the car) for a white wire with a red stripe, this is for the secondary sensor (the primary one has a plain white wire). Then figure out which sensor plugs into there and that's your secondary O2.
Old May 19, 2005 | 07:36 AM
xviper's Avatar
Finally! Here is the one for the header:
"moparacker", GOOD INFO!
Jeaners
Feb 3, 2014 09:51 PM
chikin tities
Apr 22, 2010 12:56 PM
LHP_Sailor1P
Jul 30, 2006 03:36 PM
Trip
Nov 5, 2005 01:34 PM
