is this a problem?
Originally Posted by alejo,Nov 8 2005, 08:55 PM
did you use a spray break cleaner? perhaps trigger happy?
__________________________________________________ _______________
I still think it's possible that the shock is leaking. Follow that "grease spot" up under the upper shock shroud tube with a flashlight. Does it go into the protected area? If it does, it's likely a leak.
I would try to clean the area the best you can, then after a few hours/days look at it again, if the mark returns I would suggest that your strut is shot or soon to be. Not to worry, if it is blow it is an easy fix..
