Problems with front Camber/Caster
The previous owner of my S had bumped the car around a bit, nothing too extreme (hood is original, only replaced parts i see are are front right fender, lower crossbeam(front) and the right front lower control arm (replaced with used part).
My car is pulling to the right a bit and ive had a shop do an allignment and from the report i see that the rear is within spec, but the both the front are out of spec, the right worse than the left. However according to the shop they have fully adjusted the camber/caster of the front, and cannot adjust any more.
What are my options, I understand replacing the control arm should help, but only if it is also damaged in some way. Ideally I should get the frame up on a rack and do a slight bit of pulling.
But what are some aftermarket options which will allow for further adjustment of the front camber/caster???????
any help would be seroiusly appreciated.
james0933
Aug 18, 2014 03:12 PM
