Proper steering wheel technique?
Originally Posted by TheChemist,Nov 5 2006, 02:38 PM
10 and 2 for the street and 9 and 3 for the track...
Many track cars have faster steering ratios, so by holding the wheel at the the 9 and 3 you can go from lock to lock with only some (or none)arm cross, on the street the ratios are slower and 10 and 2 with "the shuffle" is the preferred technique.
Note: add the subtleties Pantera mentioned, and you'll have a technique that will be perfect for street and track.
Re safety, it's not an airbag thing, really -- any time you curl your thumbs around the wheel, you're at significant risk of tendon damage regardless, so the point is to avoid airbag deployment... 9 and 3 is safer because it enhances control, particularly when concentration lapses (which it does, to each of us).
If I need to quickly crank the steering wheel to perform a U turn, (low speed) I go hand over hand. If I'm turning just a little bit, I use the curly shuffle.
So, I guess I use both techniques.
Why is arm crossing bad??? Because if you suddenly need to input more steering you can't and if you need counter steer your arms and hands will be in the wrong positions UH-OH!!!
I had two cross my arms twice more to get the steering wheel back where it was before I began to spin
Crossing arms, or even shuffling in a Formula car is something a person would never do, but in this situation, it allowed me to regain complete control of a car that was way out of control.I have never seen anyone rotate a car that far and not rotate the rest of the way around.
Unless I'm doing a U turn at very low speed, arm crossing is not necessary.
I dont know what you guys are talking about but.....
In an s2000, you never keep your hands on 9 and 3. I will leave the track out for a second, Ill talk about street for a minute.
YOU NEVER keep your thumbs poking through the wheel. If you slam a pothole, you will snap your thumbs off.
The s2000, track or street, is supposed to be held at 10/2. Do you notice the thicker grips in those positions? They are there because thats where your hands should be. Moreover, the spokes on 9/3 interfere from holding the wheel properly. Ideally, 10/2 provide you with the most control, and the most levarage on the steering wheel. A seasoned pro with EXCELLENT car contol skills can use 9/3, holding the steering wheel loosely, and NOT stick their thumbs through the spokes.
Ideal: http://video.google.com/videoplay?docid=-3...000+track&hl=en
If you watch the video closely, sometimes when the driver shifts, he puts his hand on the 3 oclock position, then quickly moving to the 2 oclock.
Finally, YOU NEVER drive a car with your palms. (Spirited driving that is)
Flame on.
Flame on.
It just different way to do the samething, i personally use fixed hand on track it just faster for me some of my friend and my dad use shuffle hands and they are just as fast.
in some country you need to learn both ways before they pass you for liscence, funny huh? and then my dad told me they make you parallel park on a hill and you have to hold position with clutch and gas only, no ebrake or stopper(until it's parked)
Originally Posted by cthree,Nov 5 2006, 11:09 PM
You need to ask your mama that one
Steering a car.
Originally Posted by RED MX5,Nov 6 2006, 01:26 AM
I wont go as far as saying its wrong, I personally, dont think that is the best position.
On top of that, physically, 9/3 is harder on your muscles than 10/2. (no weight support)
right I've got that
