Pumping Nitrogen into tires?
Old Oct 11, 2006 | 11:03 AM
S2000380's Avatar
Originally Posted by fonzy_S2K,Oct 11 2006, 09:35 AM
they put nitrogen in airplane tires.
this is true I do it at work
Old Oct 11, 2006 | 11:12 AM
geoff2005's Avatar
Originally Posted by fin man,Oct 11 2006, 11:40 AM
Make the car lighter. Use helium.
haha maybe you can even fly
Old Oct 11, 2006 | 11:18 AM
FormulaRedline's Avatar
Replace the helium with hydrogen and valve stems with spark plugs and I'm sure he could.
Old Oct 11, 2006 | 11:35 AM
00S2K01S4's Avatar
Costco uses nitrogen when you have tires installed there. Doesn't cost extra and I believe better than using air imho. Call first to make sure your Costco does.
Old Oct 11, 2006 | 11:45 AM
The nitrogen has so little benefit over air that there will be no noticable difference unless you are pushing the limits of racing the car. And even then, unless you've got a nitrogen tank on hand, being able to increase or decrease the pressures at will is going to be more valuable.
Old Oct 11, 2006 | 12:04 PM
Jeep Guy's Avatar
We use alot of either CO2 or nitrogen in the off road arena mainly as its a convienent portable source of gas for reinflating tires. We typically need to run at 7-10psi off road and then air up for the road. Neither gas will hurt your tires or put you in harms way and frankly, I'm thinking about changing careers after reading this. $65 bucks for a fil lof 4 small car tires is hugely funny - I can refill my 40lb bottle with CO2 for $8.50 and that will refill all the tires on my Jeep, trailer and Suburban at least twice.
If I were at the track, I would carry a bottle for the car but for regular road use, its a complete waste of money and time IMO....stick to good ol compressed air.
Old Oct 11, 2006 | 12:36 PM
Ks320's Avatar
I'm mad now. They put synthetic oil into my engine at my 3750 mile/6-month oil change.
The oil change turned out to be 55 bucks instead of 35, because they are using synthetic.
Firstly, I don't want synthetic before 7,500.
Secondly, they didn't tell me about in the beginning. They only called me during the day, when I lost my cell phone and don't have access to my voicemail. Can't really complain (and ask them to take it out) or sue them since they technically called me.
Nevertheless, this dealer is on my $#!+ list.
Old Oct 11, 2006 | 12:50 PM
PanteraKitty's Avatar
I wouldn't bother with the nitrogen fill unless I was going to do some serious performance driving like autocross or road racing.
The idea is that water vapor expands and contracts so your pressure varies with temperature. Rule of thumb among the local autocrossers is you get 2 PSI increase in pressure with each 10
fraserscrane
Apr 17, 2011 05:22 PM
S2000_rider
Aug 19, 2006 08:08 PM
michaelr
Aug 12, 2003 02:44 PM
himtall
Nov 26, 2002 10:10 AM
krazik
Jun 7, 2001 08:37 AM
