puposefully skipping a gear on upshift?
Old Oct 15, 2002 | 03:29 PM
FormerH22a4's Avatar
Default puposefully skipping a gear on upshift?
I've switched back to Honda MTF from GM Synchromesh. The GM fluid was good for cold starts and 2nd gear wasn't too hard to engage. I went back to the Honda fluid because I like the feel better when the tranny warmed up. The GM had a too loose feel when the tranny was warm.
Anyways, with the Honda MTF, 2nd is tough to get into when cold, you really have to be very deliberate and muscle it in almost. Every other gear is fine when cold. On the way home today I begain to skip 2nd and double clutch into 3rd on the upshift. I am not lugging the engine or anything here so is it alright to do this till the tranny has warmed up?
After I this this skipping on a couple starts I went back to normal and included 2nd and it was fine since the tranny warmed up.
Old Oct 15, 2002 | 04:24 PM
s2kpdx01's Avatar
i skip shift all the time. If i'm getting on the freeway, I will go from 2 to 5th or 6th sometime. As long as you double clutch or just wait long enough and are going fast enough...it's not big deal.
Old Oct 15, 2002 | 04:25 PM
ricosuave's Avatar
1-2-3-4-6 esp onto a highway.
Old Oct 15, 2002 | 04:59 PM
KennyS2K's Avatar
why do you double clutch?
your tranny is full synchro.
shift into any gear that you want, just do it without lugging or over revving engine.
Old Oct 15, 2002 | 05:02 PM
s2kpdx01's Avatar
just because you have synchros doesn't mean it isn't better for the transmission to match revs. double clutching makes it much smoother if you are going into a different gear then the natural one.
Old Oct 15, 2002 | 05:21 PM
dzfx's Avatar
I skip shift often in both cars (ie. 1st to 4th often). The problem occurs when I have to remind myself that there is no 6th gear in the truck *sigh*.
Old Oct 15, 2002 | 05:35 PM
Aldwin83's Avatar
How do you double clutch
Thanks in advance
Old Oct 15, 2002 | 05:37 PM
DVDoughboy's Avatar
Thanks in advance
I've wanted to know what this meant also
Old Oct 15, 2002 | 05:40 PM
s2kpdx01's Avatar
https://www.s2ki.com/forums/showthread.php?...?threadid=22421
search rules!!
Old Oct 15, 2002 | 05:44 PM
s2kpdx01's Avatar
ok, so double clutch...don't use the synchros.
you have to match revs too to make it work though.
what they are talking about is if you were to shift from 2nd to 5th fast....this always grinds. You have to allow the revs to drop to an acceptable level, then it slides in just like coming from 4th. it isn't like the transmission "knows" what gear you were just in.
