put on head, now no spark
Old Dec 19, 2007 | 09:31 PM
qbmurderer13's Avatar
Default put on head, now no spark
Hey guys i just re-installed the head after replacing some bent valves, now the car wont spark, we tried putting a screwdriver in the coil stick to see if it would spark but its not sending out a spark at all. We checked the ground and all the sensors and they seem fine. What is weird is that my interior dome lights arent working either. But we checked all the fuses as well and they were fine.... what can it be?
also for some weird reason the BRAKE light stays on even when the e-brake is down, it almost blinks when i put it up though.
and i just realized when the alarm is armed, i unarm it, and then enter the car, about 3 seconds later the horn beeps 3 times. is there some kind of security? my car has the factory alarm. i already entered the code into the radio if that counts?
i know this isnt the right forum but im hoping ill get more answers here since this forums much more active. thanks.
Old Dec 20, 2007 | 07:06 AM
negcamber's Avatar
Check the ground wire at the very back of the head. Easy to forget to put it on and it is a bit of a bitch to put on while the head is in place.
Old Dec 20, 2007 | 07:31 AM
i did, it was the first thing i connected while i put on the head. my car has the immobilizer system though. that green light blinks for a while until i put my key in.
Old Dec 20, 2007 | 05:30 PM
Nobody?
Old Dec 20, 2007 | 05:48 PM
what problem exactly with the factory alarm? i have the master key and the remote. It cranks but no spark is delivered.
Old Dec 20, 2007 | 09:42 PM
i checked the positive for the crank position sensor and it didnt have it so i jumped it just to start it, it idled fine and the check engine light came on which said crank position sensor. also the car didnt go past 3k. as soon as i erased the code the car turned off. im desperate please guys i need any suggestions you have.
EK9MAX
Oct 29, 2009 05:28 PM
CaymanS2k
Aug 10, 2009 08:45 PM
qbmurderer13
Dec 22, 2007 06:14 AM
s2kjb
Dec 8, 2006 11:51 PM
DVSwetwilly
Dec 31, 2004 03:12 PM
