Putting it away for the winter
Old Nov 4, 2006 | 01:50 PM
judacris's Avatar
Default Putting it away for the winter
How often should I start it up to keep the fluids running throught it? I put it away for the New York winter
Old Nov 4, 2006 | 01:57 PM
fastD's Avatar
Most folks say that running the engine for a few minutes is harder than not running it. There is a build-up of vapor that doesn't get a chance to evaporate as it does when you drive the car for 10 miles or so - the short stop and go driving is considered extreme use. Instead of starting and running the car for 10 minutes everyother week - put a trickle charger on the battery and when the weather is good take it out for a spin.
Old Nov 4, 2006 | 03:46 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Change oil & fiter,fill up tank to the brim,wash & wax inside out,unclip the top,pump up tire press to 50 psi,disconnect battery,and don't START it,till next spring.!!!
Old Nov 4, 2006 | 03:59 PM
Conedodger's Avatar
Been storing cars that way since 1979. The only thing I would add is to buy a Battery Tender and keep the battery on a maintenance charge through the winter.
Kaneda215
Oct 21, 2009 10:48 AM
ChiTowns2000
Aug 30, 2008 07:57 PM
blackfx35
Dec 20, 2005 11:40 AM
Bear 04
Dec 4, 2005 07:03 AM
darrenlee
Oct 19, 2003 05:28 PM
