Putting top down while moving?
Originally Posted by AlX Boi,Sep 26 2006, 02:32 PM
Ahaha, nooo, 06's don't have auto up. How would you go about repairing a cut wire? Also, are there ways to open up the compartment with the plugs without breaking any of the clips?
what i did was install a switch...that way you can go back and forth at the flip of a switch. basically, cut the wire, insert one end into one end of the switch, and the other into the other end.
-----> [switch] <--------
very simple. wish i'd have known you could do this w/o removing the panel though...i ended up breaking one or two of the clips!
Just pull the cover, gently but firmly. The second time I did this I used no tools other than a Swiss Army knife and it took me less than a minute.
I figured since Porsche lets their tops go up and down up to 31mph, that's probably a good cut-off.
Originally Posted by JLUDE,Sep 26 2006, 02:24 PM
Unless AP2's have auto window and top up switches I can't imagine how you manage to steer, push and hold the top up switch and pull and hold BOTH window switches at the same time!
do you guys take out the clips with your hand or use some kind of tool? im still having trouble with it
Originally Posted by Bz2005s2k,Sep 26 2006, 06:39 PM
I added auto up and auto down to both driver and passenger side window switches
Why does it not come from the factory this way??? It is 20 cents more for the switches
