Question About Clearing Headlight Diffuser
Old Oct 16, 2007 | 12:09 AM
albe's Avatar
Default Question About Clearing Headlight Diffuser
Is it better to use a heat gun to take of the sealant or should i oven it?
Old Oct 16, 2007 | 01:29 AM
AlX Boi's Avatar
Oven it. It only takes about 12 minutes.
Old Oct 16, 2007 | 02:40 AM
RunUrAss's Avatar
isnt the headlight housing plastic? i've never done it but i'd probably use a heatgun just incase..might take longer but i'd rather waste time than waste a good chunk of money to get a brand new headlight housing
Old Oct 16, 2007 | 02:42 AM
dyhppy's Avatar
oven, heats evenly
Old Oct 16, 2007 | 02:45 AM
sparrow's Avatar
i used the oven worked like a charm
Old Oct 16, 2007 | 05:30 AM
AlX Boi's Avatar
Just make sure you put it on a wet towel in the oven so the case won't get burned. The towel might get burned if it starts getting too dry, so keep wetting it each time you put the headlight in. Wet, not drench, and you'll be A okay.
Old Oct 16, 2007 | 07:42 AM
my2ks2k's Avatar
oven works fine. also some people will suggest taking the ballast off first, it's not necessary. i've done multiple clearings and left everything intact. just follow these instructions http://ricks2k.com/info/instructions/diffuser.pdf. good luck!
Old Oct 16, 2007 | 12:59 PM
rajun asian's Avatar
I know the directions say to use a wet towel but I did it dry for fear of moisture getting into the housings. The towel didn't burn in my case.
DISCONTD
Mar 26, 2012 11:39 PM
Vsdanny
Jun 13, 2007 01:56 PM
Rickjames
Apr 23, 2005 07:20 AM
