Question about handling
Old Sep 9, 2003 | 04:21 PM
0002s's Avatar
My S2000 handles very poorly, it is very tail happy going into turns and I actually have to take turns close to the suggested speed to avoid having the car spin out (already happened to me twice, very lucky I didn't hit anything, thank God, fingers crossed). And if it is even slightly wet, it feels like I am on snow. Somehow the handling didn't feel that bad when I test drove it.
I know it is probably because of the Dunlop tyres the previous owner put on them which looked very new and impressive when I was bying the car. But how can I be sure it isn't something wrong with the setup of the car before I spend a small fortune on getting new tyres and find it hasn't helped the handling much?
Before someone else points out, I am not a pro but I am not doing anything stupid like braking or shifting mid-turn.
Old Sep 9, 2003 | 04:27 PM
3ngin33r1's Avatar
My guess would be either the tires suck or they haven't been broken in yet.
Old Sep 9, 2003 | 04:29 PM
koala's Avatar
Keep it simple for now
1) Check your tire pressures. They should be around 32 psi.
2) Check out what type of Dunlop tires they are. Maybe the previous owner put crappy tires on the car to sell it?
3) Check the size of the tires. I hope they're 245/45/16.
4) Are the front and back tires the same brand/model?
Power1Pete's Avatar
[QUOTE]Originally posted by 0002s
[B]My S2000 handles very poorly, it is very tail happy going into turns and I actually have to take turns close to the suggested speed to avoid having the car spin out (already happened to me twice, very lucky I didn't hit anything, thank God, fingers crossed). And if it is even slightly wet, it feels like I am on snow. Somehow the handling didn't feel that bad when I test drove it.
Old Sep 9, 2003 | 05:55 PM
xviper's Avatar
I'm going with these! ^
Old Sep 9, 2003 | 06:30 PM
negcamber's Avatar
As said...start with the tires, but if the handling problem continues, then get a 4 wheel alignment.
Old Sep 9, 2003 | 06:51 PM
SanchothePanda's Avatar
Check your spring spacers. The dealership may not have removed them, which would account for your bad handling. Look for black disk-type things between your springs.
Old Sep 9, 2003 | 08:16 PM
Lunacy's Avatar
check for tire pressure and size
Also, make sure to have consistent throttle during the turn.
Old Sep 9, 2003 | 09:23 PM
RhodyRandy's Avatar
My personal experience is that tire pressure makes a HUGE difference in the S2000....HUGE.
Remeber 32 PSI is cold, meaning leave it in the garage overnight and then check it...
Old Sep 9, 2003 | 09:34 PM
lig's Avatar
lig
All of the above suggestions are good. One additional thing to check would be your alignment.
Excessive toe out in the rear will bias the car towards oversteer.
