QUESTION about spacers
Old Aug 5, 2008 | 04:19 PM
velocityracer's Avatar
Unhappy QUESTION about spacers
im going to have to run spacers up front for my BBK and was wondering about it? what will i need besides the spacers? longer studs? open ended lug nuts?
Thanks, Steven
Old Aug 5, 2008 | 10:59 PM
s2k dre's Avatar
u can use longer studs with slip on spacers or just get bolt on spacers from projct kiks!
Old Aug 6, 2008 | 01:53 AM
Eyal s2k's Avatar
I run 5mm spacers on the civic track car. They came with extended studs. I'd assume you should go with extended studs, but the rule of thumb is usually if you can't get at least 6 complete turns on the lugnut, then get extended studs.
FYI, i am getting about 5 complete turns on the civic with the stock studs (wanted to wait till next alignment to install extended studs) They survived Laguna Seca. Take from that what you will.
Old Aug 6, 2008 | 05:01 AM
shamoo's Avatar
That's good info to know actually. Only 6 though? Don't remember exactly, but with a stock wheel/studs, you get like a whole lot of turns right?
Old Aug 6, 2008 | 03:54 PM
thanks....mines a daily driver but no track time here....just a cruiser . Thanks everyone
Old Aug 6, 2008 | 04:02 PM
Voodoo_S2K's Avatar
The risk is up to you. I added a 3 mm spacer to clear my BBK's and I put longer studs on. I filed it under the "better to be safe then sorry" file.
13darkknight
Sep 12, 2010 05:31 PM
bayareas2k
May 6, 2010 08:13 AM
SilverStoneBullet
Mar 15, 2010 05:18 AM
fishs2000
Feb 18, 2010 04:24 PM
