question about weight and oversteer?
Old Jan 7, 2009 | 03:09 PM
  #31
krnmike's Avatar
Originally Posted by ZDan' date='Jan 7 2009, 03:55 PM
This is a different question, actively moving weight.
it isn't a different question. it's about where you position the physical matter that was already on the kart.
Old Jan 7, 2009 | 03:24 PM
  #32
ZDan's Avatar
Adding downforce is TOTALLY different from adding weight!
With downforce, you increase normal force while adding negligible mass. 100 lb. of rear downforce, with little to no additional mass at the rear will reduce oversteer/increase understeer. You've added lateral grip without adding very much at all to the mass that has to be laterally accelerated.
Adding 100 lb. of MASS at the rear is fundamentally different. You won't get enough additional rear grip (again because of the nonlinear nature of tire grip vs. normal force) to compensate for the additional mass. More oversteer.
Old Jan 7, 2009 | 03:27 PM
  #33
krnmike's Avatar
yea i know
Old Jan 7, 2009 | 03:29 PM
  #34
ZDan's Avatar
It is a somewhat different question. If you are dynamically moving your mass within the cart, it is a dynamic situation. The instant you begin to push your own mass rearward, you temporarily load the front and unload the rear. When you stop accelerating your mass rearward, you load the rears and unload the fronts. The final steady state situation is that you have put more weight on the rear wheels of the cart, but what has happened during the entire process is that more weight initially went slightly to the fronts, then to the rear.
The original question was regarding the oversteer/understeer behavior of a car with more static rear weight bias.
QuePasaKielbasa
Sep 25, 2015 04:56 AM
Raff
Mar 25, 2009 06:52 PM
Onehots2k
Jul 4, 2007 06:56 AM
Rickjames
Jul 25, 2004 08:32 PM
BrandonS
Apr 25, 2003 11:47 PM
