Questions about cross drilled rotors
Sorry if this strikes some of you as a very elementary/redundant question.
I have really been considering getting a set of cross drilled + slotted rotors (they look cool
). I just wanted to ask if they do offer any real performance advantage.
Other questions:
1. Can I just change the rotors and keep everything else in the brake mechanism stock?
2. Will it still be possible for me to use Rick's upcoming powder coated calipers with a new set of cross drilled rotors?
3. Any reliable brands/sources from where I can procure a good set of cross drilled rotors?
Thanks for your help guys!
). I just wanted to ask if they do offer any real performance advantage.Other questions:
Moneeb, yes, you can change just the rotors. The only trouble you could run into is if the rotors are too wide for the stock caliper to fit. You would run into this if you got rotors that are vented for the rear.
I don't see why Rick's calipers could cause a problem, as long as the rotors you get have the same dimensions are the stock rotors, you are dancin'...
MG Racing supplied the rotors that are on my car. Here are a couple of shots...
Here's one with Brad (meat) holding the old one next to the newly installed one...
Here are lots more shots...
http://albums.photopoint.com/j/AlbumIndex?...&a=12663856&f=0
Keep in mind that they may look cool, but the point of the slotting and drilling is to provide cooling, and thereby increasing the performance of the already very good stock brake system...
All four rotors sell for (I think) 895 dollars. They save about 3 pounds of unsprung weight on the fronts, but no weight savings on the rear...and the blue part on mine (it's called the 'hat') comes in a variety of colors, silver, red, black, etc...
Anyway, if you have any questions, ask away...!
Thank you very much for your reply Greg - I really appreciate it
Couple of questions:
1. Have you noticed any difference in braking after switching your rotors? Is the stock ABS system still fully active. The reason I ask is because even though I wish to get rotors for cosmetic reasons, I in NO way at will wish to diminish the strong braking capability of the stock system.
2. The MG rotors look real nice on your car
. Do you know if there is an option of getting both the hat and the remainder of the rotor in gold?? I have a yellow stook and I was thinking that gold rotors with Rick's yellow calipers with black S2000 logo on them would look real nice!
Thanks man - really appreciate the advice
. Do you know if there is an option of getting both the hat and the remainder of the rotor in gold?? I have a yellow stook and I was thinking that gold rotors with Rick's yellow calipers with black S2000 logo on them would look real nice!Thanks man - really appreciate the advice
[QUOTE]
The hats are really only visible off angle. If you look straight on at the wheel, you can't see the blue on mine. That, of course, will be different with other wheels.
Check out the pics at
http://albums.photopoint.com/j/Albu...&a=12663856&f=0
weird link didn't make it, but I think its this one that you are referring to in your pp album.
and this one straight on.
not bad at all, even in blue. I dont think I'd go for red on a red car anyways, but that's just me.
