Quick oil question
Old Apr 24, 2002 | 08:00 AM
2002S2K's Avatar
I have heard in the past that to switch between the two will cause various seals to expand and contract which is not good and the blended stuff, I would stay away from it, just choose one, preferable 100% synthetic, it lasts longer and is nicer to your car. Remember just because a company provides it doesn't mean it is good...
Old Apr 24, 2002 | 10:25 AM
Gymniac's Avatar
Great!! Now I have to know which Brand it was exactly ? Label on my Castrols say that synthetic and conventionals are "compatible." I guess that means it's ok to mix the two...anybody work at Castrol ? Why is synthetic better than the conventional? I know I'm making fuss of nothing but just want to make sure what I'm putting into my baby . BTW it's funny I don't remember going through this grief when I had my Prelude (not that lude is a bad car) . Thanks guys.
Old Apr 24, 2002 | 02:46 PM
twohoos's Avatar
Dude, don't sweat it! You're just topping off! For that purpose any SJ or SL oil is fine.
When they say "don't mix" they mean don't use the leftover 1-1/2 quarts of 5-30 Pennzoil conventional from your Civic six months ago with the 2 new quarts of Mobil 1 synthetic 10-30 you just bought and the quart of Castrol Syn-Blend 20-50 your ol' college buddy gave you last year...
Sheesh...
Old Apr 24, 2002 | 03:08 PM
Speedracer's Avatar
only Merceded and BMW and a few others use sythetic to start
When I bought my 328 it didn't come with synthetic oil...
Old Apr 25, 2002 | 03:08 AM
Gymniac's Avatar
ok thanks guys. I just put about 1/8 QT of Castrol GTX (conventional) this morning...every one clap . I wasn't really sure about how reliable my oil level readings were. Everytime I dip the stick and pull it out I would get different readings. Just this morning, one side of the dip stick read 1 notch above L and on the other side I saw 3 notches ...wipped it off and dipped it again....same result! May have to do with the oil being cold and too viscous (looks a lot darker in color as well)? Or could be I actually started motor and then turned it off to check the oil level spewing the oil all over inside messing up my reading?
So I ended up just putting "little."
Old Apr 25, 2002 | 03:43 AM
2002S2K's Avatar
About the BMW and M-B thing, I am not sure, although I am pretty sure that my mother's Benz did come with synthetic, because I called up to see why the first oil change was after 10,000 miles. About BMW, I just thought I had heard from my friend with an M3 that his beemer came with it too, sorry about that if I was wrong althought the M series may be different.
Old Apr 25, 2002 | 05:00 AM
StwoK's Avatar
[QUOTE]Originally posted by Destiny2002
[B]Doesn't matter.
Old Apr 25, 2002 | 08:35 PM
twohoos's Avatar
One side of the dipstick almost always reads lower -- the engine block is tilted! Use the lowest reading.
Mobil1's web site lists the cars for which it is the factory fill.
S_KAR_G0666
Sep 14, 2011 02:17 PM
.F1
Mar 4, 2010 05:59 PM
Bobba
Nov 16, 2007 06:36 AM
ATL2KS2K
Mar 8, 2005 09:05 PM
S2000boy
Jun 25, 2002 07:55 PM
