Quick Voodoo Shift Question (aligning shift pattern)?
Old May 17, 2004 | 02:13 PM
Hokie_S2K's Avatar
Default Quick Voodoo Shift Question (aligning shift pattern)?
I just received my shift knob from Rick's and it looks great! I got the pearl aluminum shift knob with the engraved shift pattern. I love the way it sits on the shifter and how it looks.
But, when I went to put it on I can't get the shift pattern to align correctly. Every time I tried to hand tighten it, the pattern always ends up upside down. I didn't want to try to over tighten it to adjust the pattern and run the risk of stripping the knob. It seems that the only way to get the pattern to line up is to screw it on (hand tight) then back it off about a half a turn, but then it's not very secure and will rotate around when driving.
The question is, should I tighten it then back it off to get the pattern to line up then use locktite secure the knob? I've read some threads where other people have used locktite, but was curious if anyone had problems aligning the shift pattern and still keeping the knob tight on the shifter.
Any suggestions would be greatly appreciated.
Thanks.
Old May 17, 2004 | 03:29 PM
Scanman's Avatar
Once you get it aligned, use a wrench and tighten the nut under the knob, it's used to lock it in place.
Old May 17, 2004 | 03:30 PM
Road Rage's Avatar
Use Blue threadlocker of any manufacture, line it up the way you want it, and do not touch it for at least 24 hours so it can set properly. You will have absolutely no problems whasoever doing this - I can attest to that personally.
Old May 17, 2004 | 03:31 PM
Road Rage's Avatar
No, the nut cannot be used with the Voodoo knob.
Old May 17, 2004 | 03:40 PM
TR-S2K's Avatar
You should apply good amount of locktite to the shift knob BEFORE you you screw it on. Allign the pattern then leave it alone for at least overnight or a day if possible.
Old May 17, 2004 | 03:46 PM
Hokie_S2K's Avatar
Thanks for the all responses. I went back out to the car to try one more time and I still can get the pattern to line up. So I'll pick up some locktite tomorrow and do it right.
Would it be more effective to apply the locking compound directly to the thread of the shifter rather than the inside of the knob or apply it to both the shifter and the inside of the knob?
Old May 17, 2004 | 03:51 PM
Hokie_S2K's Avatar
I forgot to ask. Any suggestions on which thread locking compound to buy?
I know Road Rage suggests any blue thread lock. Does that include locktite or a specific type?
Thanks.
Old May 17, 2004 | 04:08 PM
Roadruler's Avatar
what exactly is locktite?
Old May 17, 2004 | 04:13 PM
PMantis24's Avatar
Thanks.
Check this out...
http://www.loctiteproducts.com/products/de...bid=48&plid=153
Go to a Home Depot or Lowes and you should be able to find that. Blue is the strength of the thread locker.
Old May 17, 2004 | 04:31 PM
Rick Hesel's Avatar
Former Sponsor
As the email installation instructions indicate (I send an email with the instructions when each order ships), you spread a few drops of blue Loctite on the threads, screw the knob all the way down, then back it out to where you want it aligned. That will lock it in place, but a quick, hard snap of the wrist will enable you to loosen the knob.
I don't want to go on a rant here, but does anyone read the emails we send?
