Quick Voodoo Shift Question (aligning shift pattern)?
Old May 17, 2004 | 05:57 PM
Slows2k's Avatar
I avoided the use of loctite, but It does involve buying more tools. I placed the appropriate sized tap in a vise, then threaded the knob onto the tap. I cut a few more threads inside the knob, untill it lined up correctly on the car.
Old May 17, 2004 | 08:14 PM
Mr. Francesco's Avatar
Originally posted by Rick Hesel
but a quick, hard snap of the wrist will enable you to loosen the knob.
does this affect how you shift? im thinking about getting a ti knob from you, but i dont want it to get loose when i shift. any trouble with the voodoo knobs coming loose when you shift?
Old May 17, 2004 | 08:29 PM
03s2k's Avatar
if there is no engraving pattern, is it a simple screw on installtion of the knob?
sorry to hi-jack this thread
TriaXenginE's Avatar
I've tapped a couple of voodoo's some more, just enough so that the shift pattern lines up exactly straight. No loctite needed.
Old May 18, 2004 | 03:58 AM
Hokie_S2K's Avatar
Just to reply to some of the response:
Rick, I never recevied an email (work or home) on instructions for the knob. But it was no problem I went to your site and read the instructions on there.
03S2K, I'm assuming that if you get the shiftknob without the engraving, then you can crank down on it and tighten it good without threadlock because you won't have to worry about aligning the shift pattern.
PMantis24, thanks for the link for loctite.
Guedo512, I drove the car this morning to work. For now, I have the knob on the shifter hand tight and yeah the pattern is upside down but it never came loose from driving this morning.
Thanks.
Old May 18, 2004 | 04:24 AM
iCEE's Avatar
what size tap?
Old May 18, 2004 | 07:05 AM
Icemn2003's Avatar
[QUOTE]Originally posted by Guedo512
Old May 18, 2004 | 07:11 AM
Hokie_S2K's Avatar
[QUOTE]Originally posted by Icemn2003
Old May 18, 2004 | 07:29 AM
Originally posted by iCEE
what size tap?
10 X 1.50 mm
WVCR-V
Feb 26, 2017 07:01 AM
01SSM
May 19, 2014 08:38 AM
dkasmani
Jul 14, 2003 02:52 PM
ewalker
Jan 15, 2002 06:40 PM
