Racing Fuel?
Old Jun 19, 2006 | 06:59 PM
ChefJ's Avatar
Default Racing Fuel?
This may be a stupid question but can you run 100 octane racing fuel in a stock s2000?? I am not going to do it because of the price per gallon, but what would be the effects of running such a high octane gasoline?
Old Jun 19, 2006 | 07:42 PM
Spec_Ops2087's Avatar
Our car is optimized for 91 octane fuel. Anything higher will provide no benefit. However, if you got your car tuned to 100+ octane then there will be a benefit -- no idea how large though. Probably not that much without supporting mods
Old Jun 19, 2006 | 08:00 PM
XclusiveAutosports's Avatar
Without forced induction or higher compression if you are staying NA, using racing fuel makes no sense. It won't make any more power, but it will hurt your wallet.
Old Jun 19, 2006 | 08:01 PM
kane.s2k's Avatar
Not the best $/horsepower ratio there. You cannot take advantage of advancing the timing with 100 octane on a stock S2000.
Old Jun 19, 2006 | 08:09 PM
ChefJ's Avatar
Thats what I meant its 4.95 a gallon here in the metro detroit area.
Old Jun 19, 2006 | 08:11 PM
Sweeper's Avatar
Why?
Old Jun 19, 2006 | 08:46 PM
A bad way of putting it is this. If you cannot taste the difference between a 2 dollar cheeseburger and a 200 dollar cheeseburger, would you spend 200 bucks on the cheeseburger?
The same applies for our car. It cannot detect any difference between 91 octane and 100 octance, therefore it cannot use the advantages of 100 octane. The only reason for running a higher octane is usually running FI or a higher compression both yeilding more HP. Never heard of anyone tuning their car to run on race fuel without any big power mods to support this.
Old Jun 19, 2006 | 09:44 PM
Originally Posted by Sweeper,Jun 19 2006, 11:11 PM
Why?
Why? Because you need a power adder such as forced induction (SC'er, Turbo, or Nitrous) so that you can actually take advantage of the higher octane fuel that is more resistant to detonation, hence you can run more boost or spray safely with the higher octane fuel that ends in having more power. With a stock S2K it isn't possible to do this.
Old Jun 20, 2006 | 01:06 AM
Tolgahan Ures's Avatar
i am running 100 octane gas and j's n1 ecu with the intake,header,testpipe,exhaust combo. ı didnt notice notice any problems.
Tolga
Old Jun 20, 2006 | 01:11 AM
jzz30's Avatar
you should run 100 octane IF you have ultra high milage and LOTS of carbon deposits in the combustion chamber from driving like a grandma!
