Rattle in dash....
Old Aug 12, 2002 | 05:21 AM
HI REVS's Avatar
Default Rattle in dash....
My 2002 GP white with 2000 miles has a rattle in the dash. It is slightly left of center and only sounds off on rough roads. Has anyone else experienced this problem? I feel like the dealer would be more than willing to attempt a repair but I am not sure I want anyone pulling the dash out of my new S2K.
Old Aug 12, 2002 | 08:20 AM
chriso59's Avatar
I used to think my dad's car had a rattle in the dash until I read a thread here saying that sometimes the sun visors rattle agaisnt the plastic. It can sound like the rattling is coming from the dash though it's not... try driving over bumby roads with the visors down and see if it goes away.
Chris
Old Aug 12, 2002 | 08:50 AM
Ajjra's Avatar
I heard rattle in dash last night for the 1st time ever in my MY2002. It was a high-pitched buzzing and I was on smooth road
Old Aug 12, 2002 | 10:14 AM
asmx's Avatar
I too hear a rattle coming from the Dash area. I installed my own stereo and thought that it might be a loose connection. I'm going to check tht visor theory, although I'm skeptical. Please post if you solve the problem
Old Aug 12, 2002 | 10:16 AM
V8Eater's Avatar
If the rattle is in the dash towards the A pillar driver's side at the front then it is most likely a plastic harness that is rattling. I had this problem. If you crawl underneath the dash and use a flashlight you will see a white plastic harness. If you hit the dash with your fist and hold the harness it should go away. I just used a piece of rubber to stablize it.
Old Aug 12, 2002 | 02:16 PM
02spas2k's Avatar
i hear a rattle in the middle of the dash also. i also have a 2002 s2000. it doesn't happen all the time though. it even happens on smooth roads. i don't want the dealer to take apart of my dash so i am leaving it alone for now
MAtt
Old Aug 12, 2002 | 02:40 PM
enguyen7292's Avatar
also try checking your rearview mirror....what I thought was a dash rattle turned out to be the mirror
rattles are the most annoying things to get out....a lot of times they're not coming from where you think
good luck
B.Money
Apr 27, 2007 10:58 AM
soulcrew
Jan 25, 2006 06:47 AM
KINGKHAN
Apr 10, 2005 07:44 PM
CrazyPhuD
Jul 14, 2004 02:14 PM
jzr
Oct 29, 2001 08:19 PM
