Rear Axle Nut TSB
Old May 7, 2007 | 11:17 AM
Veilside79's Avatar
Default Rear Axle Nut TSB
As I mentioned this earlier and gotta great help from Saki GT,
I've taken my car to the dealership today to get it fixed under
warranty. Now, my car is at Carson HONDA and they said it is not
covered under TSB, besides they can not locate the problem I have
described. They are giving me hardtime about the whole situation...
what should i do ? or what can i do ?
I've repeated myself to them that it is rear right axle spindle nut that
needs to be retorqued... and yet they are ignoring it
Old May 7, 2007 | 11:30 AM
Veilside79's Avatar
anybody ?
i need to call the dealership asap ~
The problem is that my rear axle makes that CLUNK noise
and many ppl said it is the axle spindle nuts that needs to be
retorqued...
Old May 7, 2007 | 12:24 PM
SheDrivesIt's Avatar
I kind of doubt that the rear axle nut torque TSB would apply to a MY06. They should have had the correct torque applied at the factory.
Demonstrate the noise to them. Get some agreement between yourselves that the issue could be a less than tight axle nut. Show them the TSB. Ask them to try retorquing the rear axle nut. It's not very difficult.
Old May 7, 2007 | 12:36 PM
negcamber's Avatar
Where are you located? Another S2ki member in your area probably has the tools to re-torque for you. I've done 3 cars in my area.
Old May 7, 2007 | 12:38 PM
BlownAP's Avatar
man i re-torqued mine about 2 months ago, and now the noise is back? any help guys?
Old May 7, 2007 | 12:45 PM
Veilside79's Avatar
to meeh, i think this is BS~
i've owned the car for 10 months now and I don't even
drive it hard. I drive it like a grandpa cuz i baby my car
Rear axle nut becoming loose, i understand but what i dont
understand is that this will not fall under warranty work..
its a complete BS.
I could retorque it myself but that is not the principle here u know..
thx for all of your inputs though ^^
Old May 7, 2007 | 12:52 PM
Look. If you have a MY06 and it is within the factory warranty then if your rear end is making noises, it is under warranty. Simple as that (unless of course you broke something through abusive behavior -- not likely).
Not happy with the answer at the dealer? Take it to another one.
Old May 7, 2007 | 01:10 PM
Veilside79's Avatar
I love how you answered it~~~
it is like a pepto Bismo~
thx ^^
Old May 7, 2007 | 01:29 PM
negcamber's Avatar
Check to make sure that the nut hasn't shifted...might not have staked it completely. Did you replace the nut with a new one? If it's been unstaked and restaked a few times, it probably won't hold like it used to.
Old May 7, 2007 | 01:51 PM
Master Repair's Avatar
Take the nut off and use LOCKTITE extra strength thread lock on the threads. Retorque to factory specs.....
