Rear Console Material
Old Feb 10, 2021 | 05:42 AM
WidWidi's Avatar
Cool Rear Console Material
What is a good replacement material for the stuff outlined in red?
What type of adhesive would be good to attach it?
Thanks in advance!
Old Feb 10, 2021 | 05:47 AM
sam_spider's Avatar
Site Moderator
Community Influencer
It's called jute, if you search for jute automotive padding you'll see lots of options. Depending where you're putting it, a good spray adhesive is all that's needed.
Old Feb 10, 2021 | 07:33 AM
WidWidi's Avatar
spider,
thanks so much for your quick reply.
any particular brand of adhesive that you recommend for the job?
Old Feb 10, 2021 | 07:37 AM
sam_spider's Avatar
Site Moderator
I've got a can of Keyston Bros that I got from an upholsterer, it's not available retail. The 3M or Loctite stuff works well.
Old Feb 10, 2021 | 01:57 PM
Car Analogy's Avatar
Any auto trim adhesive, or also labeled headliner adhesive. 3M makes good stuff. But any brand will work fine.
Spray both pieces. The jute, and the part you'll glue it to. Wait 3-5 min for setup, place carefully (you only get one shot).
Old Feb 12, 2021 | 07:36 AM
cosmomiller's Avatar
Top Answer: 1
Jute absorbs water but is easy to get and inexpensive. I replaced a lot of mine with 3M thinsulate. Harder to find but does not attract or hold water (hydrophobic) and is better at sound insulation.
Old Feb 12, 2021 | 09:55 AM
WidWidi's Avatar
What type of 3m thinsulate. So many out there?
Old Feb 12, 2021 | 10:12 AM
WidWidi's Avatar
I should also asked how man mil did you use? 10mil?
Old Feb 13, 2021 | 08:24 AM
Top Answer: 1
https://www.s2ki.com/forums/s2000-ta...sults-1085903/
Old Feb 13, 2021 | 09:18 AM
Orjinal's Avatar
Out of curiosity, do those materials in the rear compartment of our cars make a difference?
