Rear End Swap
Old May 20, 2006 | 08:14 AM
iDomN8U's Avatar
Default Rear End Swap
Has anyone done a swap to convert a Ap1 rear end to a Ap2?
Old May 20, 2006 | 01:52 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Why.???
Old May 20, 2006 | 02:20 PM
Jasonoff's Avatar
Banned
You know holmez... for when you slap the turbo on... everyone knowz the ap2 diff is stronger!!
Old May 20, 2006 | 05:27 PM
iDomN8U's Avatar
Closer 1,2 gear and taller 5 and 6.
I do a lot of highway driving, and having a taller 6th would be nice.
Has it been done and is it a direct swap?
Old May 20, 2006 | 05:41 PM
wing's Avatar
That's interesting
Old May 20, 2006 | 06:11 PM
Jasonoff's Avatar
Banned
You may want to do a little more research because you are 100% wrong
AP1 and AP2 both have an axle ratio of 4.10
The AP2 transmission has a different final drive ratio along with 5 and 6th gear ratio. 1-4 are exactly the same.
Swapping the differential will do absolutely nothing for you.
Old May 20, 2006 | 08:43 PM
s2kdarren's Avatar
ive swapped bumpers,the lights take soem work tho..
hardtopguy.com has a full kit for this conversion
Old May 20, 2006 | 10:48 PM
BKL's Avatar
BKL
Amuse in japan has done this swap on their car. They swapped the whole rear subframe, though. Their reason for doing it i believe was to benefit from the revised geometry of the AP2 rear (whih had no bumpsteer issue).
Old May 21, 2006 | 04:11 AM
Balzz's Avatar
Won't a rear end affect ALL gear ratios?
Old May 21, 2006 | 05:15 AM
Jasonoff's Avatar
Banned
Yes if it was a different ratio
This guy DomN8s himself
