rear plastic windows
Old Apr 21, 2005 | 04:30 AM
stuartlong's Avatar
Default rear plastic windows
Can anyone advise of a cheaper option than Honda directly to replace rear window - put roof down and it split ? Thanks in advance
Old Apr 21, 2005 | 05:28 AM
mbilderback's Avatar
I haven't seen any aftermarket window options....honestly though, I'd say just get Hardtopguy to send you a new top with a glass window...$900US if you install it yourself. A new rear plastic will cost you $250US. I'll never replace my rear plastic except with glass. I feel your pain and am in the same boat, but 3 windows later, you could have bought the glass window top.
Old Apr 21, 2005 | 01:18 PM
watermain's Avatar
I was under the impression that if you went from a plastic window top to a glass window top that there were some fairly extensive modifications that had to be done to the frames. Is this still the case?
Old Apr 21, 2005 | 01:30 PM
beanolo's Avatar
i believe so, unless it became easier over the years
Old Apr 21, 2005 | 04:40 PM
No, there are no extensive modifications, there is a $15 elastic strap set from modifry, he has the instructions. All you do is attach the straps when you replace the top and it will pull the furthest rear frame bow forward to give enough room for the glass to lay flat. So extensive mods, no, easy and very fulfilling, yes. And Hardtopguy's glass tops come with the rear defroster wiring.
Old Apr 21, 2005 | 08:47 PM
Slows2k's Avatar
Product inquiry, moving to S2000 talk.
Curated Content Editor
Sep 25, 2018 09:56 AM
quintajl
Jun 7, 2010 12:16 PM
ness1216
Jan 25, 2008 07:50 PM
bassamdp
Jun 30, 2007 10:48 AM
liu3jhong
Sep 20, 2004 07:40 PM
