Rear Wheel speed calculator for 2004!
Old Jan 26, 2004 | 10:22 AM
PMantis24's Avatar
Default Rear Wheel speed calculator for 2004!
I came across this great little javascript program written by someone under the name of fkflee. Here's his site http://www.geocities.com/fkflee/
Well unfortunately it was written for the 2003. It has the options to change the Final Drive ratio and the drive shaft ratio but the gear ratios were locked for a 2003.
Anyway, I took some time and repurposed the app for a 2004 S2k.
http://www.revillusions.com/s2000/rearwhee..._calc_2004.html
It's a very useful tool if you plan on getting 4.44, 4.57 or 4.77 gears. You can see where each gear will top out at, what the Rpm at 65mph in 6th gear will be, etc.
Thanks to the original creator whoever you are I just changed it around for the 2004. I'm probably going to throw the 2003 version in to make it easier to switch between the 2.
Old Jan 26, 2004 | 10:49 AM
stockae92's Avatar
you're welcome
i also put them here
i always wanted to redo the UI ... but until then ...
Old Jan 26, 2004 | 11:04 AM
PMantis24's Avatar
[QUOTE]Originally posted by stockae92
you're welcome
Cristiano
May 7, 2005 03:13 PM
Diatomic
Nov 16, 2004 07:19 PM
boxsterb1
Nov 4, 2003 04:02 PM
Chris Type R
Oct 2, 2003 07:13 AM
