Rear wind deflecter?
Old Mar 17, 2005 | 10:57 PM
bkimxmd2000's Avatar
Default Rear wind deflecter?
Hey guys stupid question, how can I remove my rear wind deflector or keep it from making weird crackling sounds? Any hints? I took my car to the dealership, and they didnt do squat....they even said they fixed the cracling noises from my softtop, but didnt do no good either. They tried to put some sealent or something on but didnt help out much
Old Mar 18, 2005 | 01:26 AM
KrazyKarim's Avatar
Ummm not exactly for sale forum material. Lets try s2k talk
Old Mar 18, 2005 | 07:19 AM
xviper's Avatar
Look on the rear flat surface of the deflector base. You'll see two little "caps". Carefully pry those caps off and you'll see bolt heads. Open the secret compartment lid and you'll see the corresponding nuts. Hold one, turn the other and the thing will come off.
You can try to glue on some "rubber feet" to quiet it down too. Here is mine with the full size deflector:
Old Mar 18, 2005 | 09:17 AM
VTECorona's Avatar
Did you notice a big difference in in-cabin wind turbulence with the full size deflector? How does it install?
Old Mar 18, 2005 | 09:48 AM
mns2k's Avatar
Yes, it does make a big difference. I would also recommend Ricks head rests. They stop air flow through the mesh on the top of the seats. If the instructions have not changed you uninstall the old one and carefully pry it open. Install the new one and glue together. Reinstall with the original nuts and bolts.
Old Mar 18, 2005 | 10:39 AM
xviper's Avatar
For me, going from the stock one to the full size one only changed the way the cabin turbulence existed. It was still there, just "different". It altered the buffetting affect to a point where it just came from a different direction at me. I ended up drilling it full of holes and this made the most difference. I did quite a few cabin turbulence experiments some years ago and discovered that it was better to "control" the turbulence than to try and eliminate it.
https://www.s2ki.com/forums/index.php?showtopic=30105
Check out the links in this thread for more stuff.
Old Mar 18, 2005 | 10:42 AM
BocaS2000's Avatar
Mine was making creaking noises as well, even after installing Rick's 7/8th. I sprayed a small shot of silicone into the seams where the plastic holder and clear/tinted plexi meet and the creaking sounds were remedied (3 months now). Just an idea.
FYI: Rick's 7/8th aeroscreen along with the headrest wind blockers made a huge difference.
Old Mar 18, 2005 | 11:54 AM
Muz's Avatar
Muz
Former Sponsor
Here's another option also that's garanteed not to vibrate...
KSenpai
Jul 7, 2018 05:00 PM
billiardboy904
Sep 30, 2008 01:41 PM
spa-zz
Dec 11, 2006 04:12 AM
BELGIUMPAUL
Sep 5, 2005 08:16 AM
