Recommended Engine and Gearbox Oil
Hi all,
Whats the recommended engine and gearbox oil for maintaining our S2000's? I am new so still learning. Also, is there a specific hydraulic clutch oil we should use as well and what's the recommened change intervalof this?
Thanks a million
Adrian
Thanks a million
Adrian
Adrian, welcome, and be sure to add you VIN to your profile so you show up as an Owner!
For engine oil, it's 10w30. I personally use Mobil1 synthetic (not too expensive and readily available). For dino oils, most prefer Castrol GTX. Stick with dino oil if your car is under 10k miles.
For the gearbox, I use Honda MTF. Others use Redline MT-90, GM Synchromesh FM, and others. Frequent changes seem to keep the shifter feel nice and smooth.
Don't overlook the differential as well, should be changed every 10k miles or so to keep it clean.
The clutch system uses brake fluid. Take your pick between Honda, or any other brand, just make sure you get one that has the correct rating.
There's a great thead in the notes in Under the Hood that gives links to DIY procedures for all of these maintenance procedures and more. You could spend a whole day reading them, and it's time well spent.
Thanks so much everyone. This is one very responsive forum!! How much oil do I need then for the:
Engine
GearBox
Differential
Is it recommended to change the clutch oil regularly too??
Thanks,
Adrian
Engine
GearBox
Differential
Thanks,
Adrian
5.5 quarts
1.8 quarts
.8 quarts
... respectively.
The "clutch oil" doesn't lubricate the clutch... it's hydraulic fluid used to actuate the clutch. You should change it as often as you change your brake fluid. I don't recall the interval. Probably every 30k miles.
1.8 quarts
.8 quarts
... respectively.
Originally posted by spango
i use something like 0w -20 by mobil one suppose to lubricate faster. i always thought that 5w30 was the recomemded. but what do i know
I just checked my owners manual if your area temp gets lower than 0 Deg F 5w-40 is recommended cause it has a lower heat range, other than that it says to use 10w-30.
http://www.mobil.com/USA-English/Lubes/PDS...obil1_0W-20.asp
