Red engine paint
Old Mar 13, 2012 | 05:29 AM
deanbayley's Avatar
Default Red engine paint
Alright everyone. What's the best thing to do, if anything, to stop your paint peeling off the head cover?
Old Mar 13, 2012 | 05:38 AM
grkboy707's Avatar
I tried that "Wrinkle-Plus" paint.... no good. I ended up painting it with Duplicolor Engine Enamel, white. Looks very clean, and a little ricey haha.
Old Mar 13, 2012 | 06:00 AM
dwight's Avatar
VHT Wrinkle Plus seems to be pretty good, although my skills in applying it are not.
Old Mar 13, 2012 | 06:45 AM
s2knoob89's Avatar
Powdercoat
Old Mar 13, 2012 | 10:11 AM
deanbayley's Avatar
Ok. So the s I am looking at has a few flakes in the red paint. I was surprised as it only has 40k on it.
Do I touch it up or remove and re powder coat?
How easy is it to remove and is it as simple as putting it back on and using a torque wrench to make sure bots are right?
Old Mar 13, 2012 | 02:54 PM
deanbayley's Avatar
Is there a removal guide anywhere?
Old Mar 13, 2012 | 04:18 PM
grkboy707's Avatar
Just take out the top 5 bolts, coil packs, and anything else that is connected. Be ready with a new valve cover gasket set from Honda. Also, while its off, look into how to do a valve adjustment. As for taking the old paint off (you either take all off or none, no touch up will look good), get yourself some aerosol paint stripper and something to scrape. Paint came off mine very easily.
Old Mar 13, 2012 | 11:18 PM
deanbayley's Avatar
Great thanks. What about the torque settings for bolting back on?
Old Mar 14, 2012 | 12:32 AM
jonathanyip343's Avatar
12Nm (1.2 kgf.m / 8.7 lb/ft) Use a star pattern
Old Mar 14, 2012 | 01:13 AM
deanbayley's Avatar
Mega!
