REDLINE!
Old Apr 29, 2005 | 09:27 AM
CIVICTOS2000's Avatar
Default REDLINE!
Hi ya'll doing....I just bought my s2000, very happy by the way...I came from a 03 Civic LX so its a lil different On my Civic I used to have redline limiter and it wouldn't pass over 7K RPM's...but yestarday I was rinding on the HWY actualy just gettin on it...I was on 2nd when I decided to try it and floor it!!!!!I was about 8K RPMS when I came to a uneven part of the road and my RPM's went all the way to the end ... .......has this happened to any of you'all? did I damaged something? I'm kinda worried let me know! Thanks I appreciate!
Old Apr 29, 2005 | 09:31 AM
mad-dog-one's Avatar
Your 02 S2K has a rev limiter, like your Civic, but on the S2K it is at 9K. If your car is running OK and has not been modified, I suspect that you revved to the 9K rev limiter when vtec kicked in. Drive safely and enjoy vtec.
Old Apr 29, 2005 | 09:32 AM
Wisconsin S2k's Avatar
you've done no damage.
Old Apr 29, 2005 | 09:34 AM
CaptKirk's Avatar
Nah you won't damage anything if you hit rev limiter. Just don't make a habit of it. And drive safe
Btw, I think its funny how people think a 7K RPM rev limiter is low. Most cars (non-honda) have rev limiters anywhere from 5500 rpm to 6200 rpm...
Old Apr 29, 2005 | 09:43 AM
WOW I'm Impresed with the speed of the answers, Thanks guys....but Actually What I noticed went all the way to the end.....passed 9K I got an 03 I don't if that will make a difference! Thanks
Old Apr 29, 2005 | 10:12 AM
BerlinaBlackS2kguy's Avatar
as long as it didn't rev past redline as a result of a downshift, you are fine.
Old Apr 29, 2005 | 10:14 AM
PWRMKR's Avatar
Do you think the rear wheels came off the ground? Did you have 'er at WOT? If so you might have over sped a bit and it would be hard say how much, if any, damage was sustained.
If the car is running fine, with no differences in performance, I would run it easy for a little while and see if anything pops up. If it runs fine, after that, let 'er rip.
Good Luck
Old Apr 29, 2005 | 10:26 AM
CaptKirk's Avatar
Good Luck
I still dont think that any damage should've been done... even if the rear tires came off the ground, the engine will not rev past 9K simply because fuel would be cut off by the ECU at 9K even if he was on the gas and the tires were spinning freely. You can go jack up your car or put it on a lift, and punch the gas, and youll see that it'll bounce off of rev limiter... (actually dont go and do that I was just giving you an example, lol).
Unless he somehow mangaged to GAIN speed in the AIR, he would not have over revved his 2nd gear... The second his rear tires left the ground, he would've started to slow down which in turn would mean that his RPM in 2nd gear would be LOWER than it was when he left the ground.
So with these 2 points in mind ( 1) ECU not letting car over rev even if tires are spinning freely 2) The car cannot GAIN speed in the air) I think its safe to assume that the did no damage to the car...
Now if he has some crazy wing and some propellors or turboprop engines that I don't know of, then I'm not sure
Old Apr 29, 2005 | 10:48 AM
assuming the car is either in neutral or accelerating in a gear, you won't go past about 9150 rpms. (this varies a little) Though it "looks" like you might be going past that, you aren't. The tach goes to 9k, and then that area of "red" you see, is actually a shift light in a sense. It flashes about 2-3 times before you hit the rev limiter, indicating you should shift. I actually use it when I'm racing, as I have it timed I can shift exactly at 2 blinks and into the next gear.
Again, this doesn't cause damage, as that's what a rev limiter (rev limiter is different from redline, by the way) is for. To prevent an over-rev.
Now, that aside, let's say you are in 3rd and shift at 90mph, expecting to go into 4th gear, but accidentally put it into 2nd.... this will cause a mechanical overrev, and THAT can cause some MAJOR damage.
however, accelerating to redline will not. unless you do it a lot and hold it at rev limiter. this causes tremendous stress on the rods from the piston deceleration. fortunately we have a forged bottom end, including the rods, so that helps.
Old Apr 29, 2005 | 11:22 AM
Hey I'm still impressed with the answers from you'all I came from another forum website and damn you'all are fast Thanks for the raplies!!!!!!!!
