Regular or synthetic oil?
Old Oct 14, 2005 | 02:16 PM
Superfly05's Avatar
Talking Regular or synthetic oil?
I used mobil 1 synthetic in my Z06 (not to mention it comes out of the box that way) , but I was thinking about swapping to the same for my first oil change in my 05. What do you guys think? Does it really matter in the S2000? Or am I just wasting my money? Comments?
Thanks,
Jon
Old Oct 14, 2005 | 02:27 PM
SheDrivesIt's Avatar
Honda recommends waiting until 10K miles before switching to synthetic.
Old Oct 14, 2005 | 02:30 PM
Oh yeah. Read the "Oil Journals". Everything you ever wanted to know about lubricants and the S2000 (and then some) is here:
https://www.s2ki.com/forums/index.php?showtopic=195574
Old Oct 14, 2005 | 02:50 PM
Superfly05's Avatar
Good info thanks guys!
Jon
Old Oct 14, 2005 | 03:57 PM
BlackJoker's Avatar
I use regular oil. I was using synthetic, but my car drank that like it was its job. After switching back to regular, the oil level always stays at the "H" on the dipstick and I drive the piss out of it
Old Oct 14, 2005 | 04:23 PM
NNY S2k's Avatar
I switched to Mobile 1 around the 10k mark. As my car gets older it uses less oil than when it was new.
Old Oct 14, 2005 | 04:40 PM
Scablander's Avatar
I use Chevron Supreme 10W-30 (same as Havoline GF-4 recommended in the oil journals). I change my oil in the spring and just before putting the car into semi-storage in the fall. I put less than 3,000 miles on an oil change, so there is no point in going to a higher-priced synthetic that offers longer drain intervals. The "oil journals" indicate to me that the new regular oils are good enough for the way I drive my S2000.
Old Oct 14, 2005 | 08:00 PM
QUIKAG's Avatar
I switched to Mobil 1 in my '05 at the 3,000 mile mark. It's running great and no oil loss or anything.
Old Oct 14, 2005 | 10:52 PM
Green Tea's Avatar
Probably will when i hit 10k. I'm more confused as to whehter i should follow the normal/severe condition
Old Oct 15, 2005 | 06:41 AM
PhilipLowe's Avatar
i got into a big debate about this with my buddies, i would not do it till 10k either but i could not find a tech i talked with who would back that up. they say most everything is seated properly after 1,000 mi. from what i understand the bushings ect are made w/ different compounds that in the past when synth would cause leaks.
i went to synth at 6k. no issues if it helps any...
