Remote keyless entry
Old Apr 5, 2006 | 04:58 PM
MASTERS2K's Avatar
Default Remote keyless entry
Hello,
I just notice today that my keyless entry remote was not locking my car. Everything else work but the locking button. I have two remotes and they both did the same. Anyone know what it could be? Help appreciated. thanks!
Old Apr 5, 2006 | 05:29 PM
xviper's Avatar
Does it unlock? How about popping the trunk? Panic button?
Old Apr 5, 2006 | 08:29 PM
Ed_Grant's Avatar
Blown fuse??
Old Apr 5, 2006 | 08:40 PM
jlstyle82's Avatar
i know i know!
Mine does that sometimes too! but i figured it out.
If you hear beeping sound after you remove the key from the key hole, that means your key lock was not placed back correctly when you remove the key and therefore remote won't work.
So if you hear the sound, just plug back in your key and twist a little bit to hear that "click" sound then pull it out. If you don't hear the sound no more, your remote would work fine as usual.
Well, if this is not the case, i'm sorry!
Old Apr 5, 2006 | 09:28 PM
jasonw's Avatar
Originally Posted by jlstyle82,Apr 5 2006, 08:40 PM
i know i know!
I actually just had my ignition replaced to fix this... Seems to have worked...
Old Apr 5, 2006 | 10:55 PM
E36Ap1's Avatar
Make sure your door actually closed because it won't lock if it is not.
walter22
Jun 27, 2014 09:09 AM
Jersey
Sep 1, 2008 12:53 PM
motocrossmann
Apr 1, 2008 09:18 AM
BORT617
Jan 19, 2007 11:04 AM
ED1
Dec 23, 2005 02:35 PM
