REmoving Honda
i want to remove both the front and rear H because tis hard to clean inside it and it and wax.. so i just wanna shaved them. but im not sure if there will be two holes behind it? anyone have pix and know how to removed them.. thanks
There will be two holes on the trunk lid and on the front bumper.
You can remove the badges by using dental floss to cut the adhesive on the H and the pull on the REAR H emblem. It will pop off.
The Front H emblem you will need to remove the bumper so you can remove the securing buttons/clips on the prongs. Once you remove these, you will be able to pop the front one off too.
Tim
Tim
If you wanted to remove the H emblems you HAVE too filled them in with something and then get it painted?
Is there something out there like the clips for the license plate in front to fill the holes in?
Marcus
Marcus
Marcus
Marcus
Originally Posted by DaveOnLI,Oct 29 2006, 12:35 PM
You can get the front off without removing the bumper - use a needle nose pliar to snap off the pins on the inside
and yes there will be two holes
yea... you'll look stupid rolling around with holes in the front and the back... you'll look like someone ganked your emblems...
on a side note, what adhesive would be recommended for rebadging?
