Replacement Top
Old Apr 23, 2010 | 12:45 PM
RED S2K HEAVEN's Avatar
Default Replacement Top
Have tears on both sides on MY01
What is the best repl. top to get?
Which is better, vinyl or canvas?
Read good things about E-Z Top & Robbins.
Probably upgrade to a glass heated window.
Your thoughts... & thanks for your input..
Cheers...
Old Apr 27, 2010 | 07:14 AM
Cyclon36's Avatar
OEM for fitment and no budget worries
Robbins for aftermarket with OEM quality material at a lower price (vinyl)
EZ On for the cheapest alternative. Material is on par with OEM and robbins. Installation is only a fraction more difficult.
Vinyl is going to be less maintenance than cloth and less expensive. Cloth will be a darker black but will require more maintenance to keep it looking new.
Since you have a 2001 though, I'd recommend the robbins or EZ-On since it comes with everything to retrofit the frame to accept a glass back.
Old Apr 27, 2010 | 09:44 AM
djfamousa's Avatar
dealer quoted 2300.00 installed.
found a robbins dealer and local upholstery place to install it. Total Price after install = under 1grand
highly recommended
Old Apr 27, 2010 | 01:02 PM
Found a local shop to install a Robbins canvas top w/glass for $1300.00
Seems like a good price!
Old Apr 29, 2010 | 11:15 AM
Cyclon36's Avatar
Just as a bit of info, even if you take it to the dealer, they still sub it out to a local upholstery shop about 90% of the time. MSRP on the honda top is about $1200 and wholesale on it is about $830 from most dealers (majestic sells for $780 I think but they won't ship the top). The dealer charges about $900 for install while most upholstery shops tend to charge between $500-$700 for the job.
The biggest thing to make sure any shop knows that does the jobs is that the roll hoops do NOT come apart. I've seen a ton of installs from "the dealer" where they just broke the roll hoops apart and the customer ended up having to deal with it after the fact.
Clovis
416
Nov 4, 2025 06:05 AM
Wakeupfranky
Sep 4, 2018 08:29 AM
ricky840
17
Aug 10, 2011 03:00 PM
MWillis
Aug 19, 2005 01:55 PM
