replacing drive shaft
Old Sep 24, 2007 | 11:57 AM
lude9285's Avatar
Default replacing drive shaft
Im going to replace the propeller shaft but have been doing some reading on the site that the 6mm hex box are not easy to deal with. Has anyone figured out a good to remove these. I dont have very many resources such as dremel or heat.
Old Sep 24, 2007 | 04:18 PM
S2k Dude's Avatar
One time we pounded in a torx bit then used a wrench to twist on the bit. The bolts were originally put on by the dealership who torqed the crap out of the bolts. If the bolts have not been removed previously then chances are the factory did not over tighten.
Old Sep 25, 2007 | 07:38 AM
lude9285's Avatar
Does the driveshaft have to be aligned when you put it on? or can it go in any way (as long as the front and back are in the correct directions)
I ask because on the clutch install DIY, it mentions for you to mark the driveshaft position (in relation to the tranny and diff), what happens when you put on a new driveshaft (not from your car)
Old Sep 25, 2007 | 08:07 AM
ruexp67's Avatar
The only way I was successful in removing those bolts was to cut the heads off.
Old Sep 25, 2007 | 11:04 AM
s2guru's Avatar
since i was taking the whole engine/transmission together, once i dropped the trans, i had enough clearance for the bolts
Old Oct 10, 2007 | 09:12 AM
lude9285's Avatar
anyone know where to get new hex bolts.....local dealer in LA said 4.50 a piece...can i get them cheaper anywhere else. I just want to have them on hand in case the old ones get damaged when i pull the shaft out
Old Oct 10, 2007 | 09:32 AM
lotus7racer's Avatar
When I made my own driveshaft for my Lotus 7 using the s2k Motor, I gotten 6 long bolts from my bolt bin which is made by ARP. I don't have the number since these are used hardened 6mm long bolts.
Old Oct 10, 2007 | 09:50 AM
Silver9k's Avatar
I used a 1/2" drive 6mm hex socket attached to a breaker bar, and gave so good hits (instant torque rather then constant torque) which helped to break a few of them loose. I think I first tried using a allen key and stripped one or two of the bolts, then went out and bought the socket. So needless to say my method worked at successuflly removing 3 of the bolts, the other three I had to dremel out of there.
If you have access to air, try using that first, turn the pressure up to 120-150 if you can and use a strong socket. I think if you did that, you'd have an easy time. If you can't, try doing what I did and you may get lucky. Otherwise have fun with a dremel or drill...
BTW, just buy 6 new bolts from your dealer, you are going to need to replace them...and their price isn't bad, here is a link to a site with cheap OEM parts, and those bolts are $2.20 there, but you'll also need to pay some shipping, and you really aren't saving much money
http://www.hondaautomotiveparts.com/auto/j...PROPELLER+SHAFT
Old Oct 10, 2007 | 11:45 AM
glagola1's Avatar
I used an impact gun with a 1/2 driven allen key. No problems here. I would imagine that with a typical hand held allen wrench, you could strip them pretty easily.
ex-eclipse
Jan 15, 2020 06:51 AM
WarrenW
Jul 9, 2017 05:03 PM
lude9285
23
Oct 10, 2007 10:18 AM
Atheist
Jul 13, 2006 05:20 PM
