resetting the ECU
Old Jul 16, 2005 | 09:41 AM
asn's Avatar
asn
Default resetting the ECU
The search seems to be down. Could someone please tell me how to reset the ECU? I've seen some shuddering at low RPM's, and when I start the car, the motor almost dies when it's been sitting for a day or so.
Thanks
Old Jul 19, 2005 | 05:29 PM
asn's Avatar
asn
the search is still done - Anyone know how??
Old Jul 19, 2005 | 05:40 PM
S2KPUDDYDAD's Avatar
I am sure there is a better way but .... what I do is disconnect the battery, then put the key in the on position and tap the break once just to no that any and all power left in the car is gone. Then I leave the car sit over night.
Old Jul 19, 2005 | 06:35 PM
Gloffer's Avatar
Remove the third fuse down on the right side, wait at least a minute, then reinstall the fuse. If you're getting shuddering when coming down to an idle, then you should try cleaning your throttle plate with some intake cleaner. This worked for me.
Old Jul 19, 2005 | 08:20 PM
jwa4378's Avatar
might also want to check your O2 sensor. The one on my sister's civic just went down....same symptoms. I just unplug the battery for 30 minutes with the cabin light in the "on" position. This worked on the civic.
John
Old Jul 20, 2005 | 07:12 AM
asn's Avatar
asn
thanks for the info.
is cleaning your throttle plate something I can do pretty easily, or something I should have the dealer do?
rebel yel
Mar 28, 2015 05:55 AM
Itchy Dick
Mar 19, 2011 01:59 AM
silvermonster
Oct 12, 2010 02:20 PM
Cole_19
Sep 11, 2008 07:42 AM
Cheese Steak Nazi
Oct 17, 2007 07:00 AM
