REV MATCH AND DOUBLE CLUTCH HOW TO!
Old Dec 27, 2006 | 07:17 PM
  #21
fperra's Avatar
This doesn't belong in under the hood. Moving to S2000 Talk.
Old Dec 27, 2006 | 09:06 PM
  #22
guardiase's Avatar
I'm curious about rev-matching a downshift via double clutching versus using the throttle and clutch simultaneously. At the moment I do the latter. I know that you can burn the clutch if you rev with the clutch pedal to the floor. Let's say you continuously rev in neutral with the clutch not depressed, then you immediately let off the gas and push the clutch in. Does that do the same kind of wear as opposed to revving while you're holding down the clutch?
Old Dec 27, 2006 | 09:21 PM
  #23
TheCarGuy2021's Avatar
I never double clutch upon downshifting, the S2000 isn't a big rig for pete sake, I just rev-match. Almost every slowdown I downshift as if it were my primary means of slowing down. 65,000 miles later (many supercharged) and I'm still on my OEM clutch (which has som mileage still left in it)...
With a tight throttle cable (which makes blipping the throttle much easier and accurate) and some practice, anyone can perform very smooth downshifts with minimal wear on the clutch.
I have tried double clutching, it just isn't for me and I dont find it neccesary for my conditions.
That's just me...
Old Dec 27, 2006 | 10:07 PM
  #24
common reactor's Avatar
Not to be the jerk here, but I do not rev match ever. I've been driving stick since I was 15 and have never had any problems with just pushing in the clutch and going in to gear...at any speeds. Maybe one day I will, but I've seen too many amature drivers screw their cars up cause they thought they were rev-matching.
Nice write-up though
Old Dec 27, 2006 | 10:08 PM
  #25
j03chu's Avatar
nice write up although i already know most of the information posted. good for the noobies that don't drive stick well =]
Old Dec 28, 2006 | 05:04 AM
  #26
jdm knowledge's Avatar
i think in some states you have to downshift and you can not be in neutral at a stop light.
Old Dec 28, 2006 | 06:54 AM
  #27
Ubetit's Avatar
Originally Posted by 05TurboS2k,Dec 26 2006, 01:58 PM
This method will reduce all your tranny wear issues, and if you've driven a tranny with no syncro-mesh you'll be forced to do this.
The only thing it saves is your synchronizers and in the 5 years i've been on this board I can't seem to recall one thread where just the synchros need to be replaced from wear.
Also, 99.99% of these folks will never drive a gear box with straight cut gears so let's not make it seem like it's a required skill.
IMHO, no need to double clutch.
Old Dec 28, 2006 | 07:30 AM
  #28
bronfufu's Avatar
i revmatch on downshift all the time. but i had no idea you're not supposed to rev your engine while the clutch is depressed. =(
what if im downshifting? im supposed to go to neutral, let the clutch out then revmatch then clutch in and downshift?
Old Dec 28, 2006 | 08:32 AM
  #29
turnerg1's Avatar
All this talk on rev-matching and double clutching I have to ask a couple questions.
1) Do you rev match if you are slowing to a stop or only when coming to a corner and want to enjoying the cars benefits.
2) I typically rev match to downshift at a corner but will brake and downshift when coming to a stop ( taking my foot off the clutch to allow engine to assist) any probs with that?
Thanks,
Greg
Old Dec 28, 2006 | 09:13 AM
  #30
smurf2k's Avatar
pretty much all trannies now are constant synchromesh, anyways. still, when i do a 5-2, for instance, id rather not have to 1) wait for the synchros 2) have the synchros absorb the friction and wear
on my old car, double-clutching was really a necessary to get it in 1st when rolling
dbclutch...4 lyfe!
