reverse help
Old May 2, 2001 | 11:21 AM
dannylo77's Avatar
it is very difficult for me to get into reverse, especially in the cold, i only have 2000 miles on my car. is it normal? is there a special routine before trying to get to reverse such as going to forth first? i don't want to hurt my tranny.
thanks guys
Danny
Old May 2, 2001 | 11:31 AM
STL's Avatar
STL
Have you read your manual? You do know that you have to push down on the gear knob before pulling over and back -- right?
Old May 2, 2001 | 11:39 AM
kizneda's Avatar
Wow. I hope after 2000 miles he/she knows that!
Old May 2, 2001 | 11:48 AM
1Y2KS2K's Avatar
I sometimes have a real problem trying to get the gear to notch into reverse. I usually end up having to "crunch" it. Same thing with shifting into first gear. I've demonstrated it to the Honda mechanic, but as there's no alert about the problem from Honda NA, he's pretty clueless what he can do about it. Changed the tranny oil, but that made no difference. Or whether the engines hot or cold.
Old May 2, 2001 | 04:28 PM
s2kdan's Avatar
[QUOTE]Originally posted by STL
[B]Have you read your manual?
Old May 2, 2001 | 05:42 PM
JackTs2K's Avatar
Veteran: Army
thanks guys
Danny
I used to have this same problem. Try placing the shifter in the first gear position, then over to reverse. I do this all the time now, and I don't have any problems anymore.
Old May 2, 2001 | 06:05 PM
cjb80's Avatar
This isnt anything new with the S2000, this has happened with every manual car I have owned (Z06, Civic SI, and S2k) It's natural for me to put it in first, then put it in reverse.. it seems to align .. stuff.. or .. something..?
Dont force the shifter in to gear, that's bad for the transmission.
This should happen when the transmission is cold, when it warms up it should be fine -- unfortunatly you don't need to go in to reverse while you're traveling down the highway!
Chris
Old May 2, 2001 | 06:43 PM
Utah S2K's Avatar
Here's a hint I use on my, S2000, Pantera ('74), my step dad's Diablo 6.0,as well as my '93 Jeep:
1) Put car in 1st gear..rock forward slightly
2) Shift into reverse
Old May 2, 2001 | 06:57 PM
William's Avatar
I don't think reverse is synchronized. If it wont go in reverse let clutch out then push back down and try again.
Old May 2, 2001 | 07:23 PM
Drop-off's Avatar
ya just dubble cluch in out,in out then shift
