rolling the rear fenders?
Old Oct 12, 2003 | 04:55 PM
  #21
cashout's Avatar
Originally posted by ruexp67
Before/After pix with the wheels back on?
The wheels look the same as the car is NOT dropped. You cannot tell the differenceby looking at the
car as there is so much space between the top of the wheel and the fender.
Rolling was only necessary because the tires are 245/45s.
Here is a before picture. Don't have an after
Old Oct 12, 2003 | 04:57 PM
  #22
cashout's Avatar
Originally posted by BlueS2000Boy
pics from behind!!!!
See above
Old Oct 12, 2003 | 05:04 PM
  #23
cashout's Avatar
Originally posted by 3ngin33r1
FAQ'd
Do you mean you put it in the FAQ or do you want me to?
Old Oct 12, 2003 | 05:24 PM
  #24
3ngin33r1's Avatar
No, I did.
Old Oct 12, 2003 | 06:56 PM
  #25
WRS2K's Avatar
make sure you guys figure out exactly at which parts you are rubbing before you go and roll the thing. why mess with it if it ain't doing the nasty?
my rears are 9.5" wide fitted with 255 tires, 55+ offset. this is definitely an aggressive setup and my wheels only tuck in (barely) because i am lowered which pretty much forces me to run -2.x camber in the back.
where i was rubbing was in the rear section of the wheel. you'll see what i mean by going to www.socal28.com.
rears are easy to do, but the fronts are definitely trickier.
Old Oct 13, 2003 | 08:57 AM
  #26
efthimios's Avatar
thanks for all the info....wrs2k i sent you a pm
Old Feb 5, 2005 | 01:24 PM
  #27
Nobody's Avatar
http://forums.s2ki.com/forums/showthread.p...threadid=189123
Old Sep 27, 2007 | 08:56 PM
  #28
CA_S2K's Avatar
ok so doing this will allow you to have wider wheels? or?
Old Sep 28, 2007 | 09:42 AM
  #29
chungtachicken's Avatar
Back from the dead...
Well, essentially those with aggressive offsets or wider tires roll their fenders...and those who have wider wheels usually run wider tires.
For example, a lot of people are running 17 x9 Enkei RPF1s with +45 offset and 255/40/17 tires. They would definitely need to roll their fenders or have a substantial degree of negative camber if they are lowered.
Then again, there are a lot of people who don't rub at all with wider tires...rubbing becomes an issue on the rear fenders depending on a lot of variables (camber, tire width, wheel offset, suspension travel, etc)
Froth.
Oct 8, 2013 11:22 AM
lude92_si
Apr 28, 2012 07:31 PM
milkman2089
Sep 30, 2009 11:44 AM
jbotstein1
Jun 22, 2006 08:51 AM
rorrick
Feb 9, 2004 04:17 PM
