Rolling slow in 1st gear?
Old Jul 24, 2012 | 11:43 PM
ThatsErreeday's Avatar
Default Rolling slow in 1st gear?
Hello fellow s2k owners,
I have had my s2k for a month now, and love driving it! Sadly, I am still getting the hang of my first manual car. I am having trouble letting go of the clutch to let it roll in first gear. I have to let it go real slow, or else if I let it go too quickly, the engine will bog and shake. Is this normal, or can I fix this so that I can roll faster? Thanks in advance for helping me not burn my clutch!
Old Jul 24, 2012 | 11:48 PM
Knella15's Avatar
If its bogging then that means you probably aren't giving it enough gas. When I first started driving this car it took a while to get used to it. With time you will get the hang of it.
Old Jul 25, 2012 | 12:00 AM
I thought the car could move by itself if you release the clutch without giving it gas?
Old Jul 25, 2012 | 01:30 AM
Knella15's Avatar
Yeah you can get it to sort of scoot a little but it still needs some gas to really get it moving. I also live in a hilly area so I normally cant get it to move with just releasing the clutch unless its really flat. Some experts can probably chime in here to give you better advice than I can because I have only been driving my s for about a year so I still have lots to learn also.
Old Jul 25, 2012 | 03:09 AM
NNY S2k's Avatar
Levi
Old Jul 25, 2012 | 04:00 AM
RedCelica's Avatar
on a cold start and flat ground yes....otherwise not really unless you're pointed downhill.
Old Jul 25, 2012 | 05:42 AM
whiteflash's Avatar
Roll in first gear? Move without giving gas?
Old Jul 25, 2012 | 05:55 AM
Drkphnx's Avatar
Like it was said, on a cold start your rpms are already high enough to get it rolling without giving it gas "throttle"
Old Jul 25, 2012 | 06:43 AM
Presto123's Avatar
This is much easier in a car with torque..
Old Jul 25, 2012 | 07:10 AM
rustyshackle's Avatar
if it's shaking, you just need to push the clutch in just a little bit more..
you can move without giving it gas.. just find the point where it catches..
when you find it, you can roll foward or backwards with just the clutch
