Roof not installed right?
Old Aug 14, 2009 | 03:12 PM
badboy00z's Avatar
Default Roof not installed right?
I bought the car used with an aftermarket top and it doesn't seem to look right compared to others I've seen.
Here are the pictures:
The passenger side is slightly better but not as tight as seen here:
I notice a lot of (wind?) noise and I think that's the cause.
The windows don't go up any further either. What's my best course of action? Can it be fixed without getting a new top or frame?
Old Aug 14, 2009 | 06:57 PM
Tylersp's Avatar
they previous owner probably just did it himself, would be a real pain trying to take the top back off to fix it. i know this cause i put mine on myself, just try buying some new strikers
Old Aug 14, 2009 | 07:58 PM
ziggy55's Avatar
yea doesnt look right at all, btw what MY is your S?
Old Aug 14, 2009 | 08:57 PM
Tylersp's Avatar
you can always try to redo it buy your gonna have glue and rivets to mess with, took me 3 days on an off to put mine only by my self
Old Aug 15, 2009 | 01:48 AM
badboy00z's Avatar
2001.
Old Aug 15, 2009 | 05:20 PM
barbara4044's Avatar
That top looks like crap, excuse my bad way with words. I just had a new top put on and it looks pretty good. Nothing is as good as it is when it comes brand new. Good luck. My top was about 1500.00, btw.
Old Aug 15, 2009 | 06:18 PM
Snowmoto125's Avatar
Lots of wind noise? Does the top leak at all? I would assume yes with the extra wind noise?
Old Aug 15, 2009 | 06:20 PM
iam7head's Avatar
if you have a steady jet of air coming from the two side when you rode on the highway, check the cable tension for the two side, it's a spring loaded tensioner that tighten the side for a better wind seal
the s2k top is 99 percent like the miata top, it has 2 cable on each side for cutting down the wind noise, the best way i could think of is by pulling down the top half way and inspect it there.
if it's not installed/not installed probably/broken spring the side will look and feel "loose" since there's no tension present
<---done number of top install including miata/s2k
edit: the side looks really loose,it could be a bad install or bad laser cut top, or a combination
Old Aug 16, 2009 | 01:39 PM
badboy00z's Avatar
It hasn't been in heavy rain yet but it doesn't leak when I wash the car.
What does the tension cable look like?
Also how much would you charge to install a top?
Old Aug 18, 2009 | 01:56 AM
iam7head's Avatar
dealer charges about 8-10 hr, i think it's about right for a 2 mens installation.
For experienced installer(and good fitment top) you can get it done in 6ish hours, assuming no custom work needed in terms of fitment or rear glass conversion,etc
the tension cable is just a SS cable with a coil spring attach to it, it should be fully enclosed if it's installed right, try pull on the edge of the top(where the highest point of window meets the roof) to see if you can get some slack there.
it should be snuggly fastened if the cable is working/installed correctly.
phase_k
Sep 20, 2013 12:46 AM
S2000 RMO
Mar 10, 2010 10:00 AM
Jonsey Boy!
Car Talk - Non S2000
26
Jul 7, 2008 10:28 AM
billybiker
Dec 7, 2006 11:40 PM
GTFCTIM
Apr 19, 2005 04:59 AM
